Lower Control Arm Removal
Results 1 to 3 of 3
Thread: Lower Control Arm Removal
    Oct 2007
    DENVER
    26
    I have most of the lower control arm almost removed from 2K G20. My current problem is the last bolt and nut which is located with the cutter pin is giving me a difficult time to remove. I was able to remove the cutter pin but the bolt is totally rusted from the car being in Florida. So far I have tried blow torch, pb blaster, WD 40 with no luck.
    G20 Guru brammes's Avatar
    Oct 2006
    masshole
    1,235
    youre trying to get the nut off right? just keep using heat and blaster...and use a breaker bar if you can squeeze it in there. it'll come off. if i could get mine off with all the salt they use up here in mass and rust and shit then im sure yours will come off. use a ball joint separator once you get the nut loose to pop the ball joint out of the knuckle
    Oct 2007
    DENVER
    26
    You are correct, I am trying to get the rusted nut off to remove the bolt joint and install a new control which includes new joint.
