Taking the plunge
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Taking the plunge
  1. #1
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Taking the plunge
    I'm finally joining the darkside! Picking up the ve motor tomorrow from Japan Star Engines in NY! Getting it for $700 because my friends are picking up an
    H23A vtec swap and a 2jzgte swap, so it was kind of a package deal. I can't wait to put this motor in and see what it can do! Daveracer, we have another project on our hands! I'm finally saying goodbye to DE-T performance after 7 years
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    Yeah That Just Happened! Dane's Avatar
    Join Date
    Aug 2004
    Location
    Oak Town, Wa
    Posts
    14,167
    What car is this going into?
    Quote Originally Posted by Blackwater32 View Post
    Someone quote me.
    Dane, don't quote me
    WWW.TOP5DOA.NET
  4. #3
    rhd specialist j-tek's Avatar
    Join Date
    Apr 2005
    Location
    bay area
    Posts
    4,840
    sell me the t28
  5. #4
    G20 Senior Member P10 Goodness's Avatar
    Join Date
    Sep 2008
    Location
    Mesa, AZ
    Posts
    686
    Nice I'd be interested to see what you have to say about the drivability and comparison of power feel. Naturally it is kinda like apples and oranges, one is turbo'd and one's NA'd. But would be interesting to compare the two.
  6. #5
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Dane- it's going into my p10
    j-tek - I will be turbocharging the ve so I'll be using this
    P10 goodness- I'll try it N/A first, but I will definitely transfer all my turbo parts onto this motor.
  7. #6
    drunken master p10det's Avatar
    Join Date
    Dec 2003
    Location
    de
    Posts
    9,890
    with the cost of the engine being low I would upgrade the pistons and rods and full bottom end blue print to ensure a reliable set up. the VE is week in the knees.
    also the h23 blue top vtech is a pretty rare engine
  8. #7
    G20 Senior Member JLWOLD's Avatar
    Join Date
    Apr 2008
    Location
    Spokane, WA
    Posts
    504
    i would only imagine a little more torque out of the ve over the de-t. but hell! i have no idea what i'm talking about, i've never had either
  9. #8
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Good point p10det. That would be down the line as I also have the slowport out of a p11I swapped in my p10. Thinking of a LS/VTEC type build on the ve. I would probably save that for 2011 though. This year, I wanna put the ve in, run it with the set-up on my car right now, and add a b14 tranny. Engine is super clean in and out, btw.
  10. #9
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Quote Originally Posted by JLWOLD View Post
    DE's are fun, but when I drove Daveracer's car and it was N/A... it just felt sooooo much stronger than a DE.
  11. #10
    Join Date
    Apr 2008
    Location
    Spokane, WA
    Posts
    504
    just to be clear, when you say "sooooo much stronger" your talkin about the ve, correct?
  12. #11
    Join Date
    Apr 2008
    Location
    Spokane, WA
    Posts
    504
    i'm just not aware of daveracer's setup
  13. #12
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Sorry for not being clear. Yes, the ve set-up felt so much stronger than a DE with bolt on's. The thing was ripping tire on top of second gear when the vvl kicked in. I haven't driven Dave's set-up with the t25 kit, but he said it feels like a raped ape on 'roids. We basically have the same turbo set-up. So I hope I get the same results as he did.
  14. #13
    Join Date
    Apr 2008
    Location
    Spokane, WA
    Posts
    504
    haha noice! i wanna drive your on the wrong side of the country man!
  15. #14
    Join Date
    Apr 2005
    Location
    bay area
    Posts
    4,840
    yo bogs (ben)! you gonna run an aftermarket pulley set w/ the ve?
  16. #15
    Join Date
    Sep 2008
    Location
    Mesa, AZ
    Posts
    686
    Quote Originally Posted by Crazy4myP10 View Post
    Very cool. I know the VE intake manifold and head flow a lot more air than the DE design. The high lobe cams will definitely help to get the most out of your turbo at high RPMs.
    I'm running an NA VE right now and plan on going VE-t in next year or so.
  17. #16
    G20 Guru
    Join Date
    Jan 2008
    Location
    CT
    Posts
    1,522
    welcome
  18. #17
    Join Date
    Apr 2008
    Location
    Spokane, WA
    Posts
    504
    i need to join this club
  19. #18
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Quote Originally Posted by j-tek View Post
    I got a G-spec water pump pulley that's on my slowport right now that I'm gonna be using and I'm gonna sell the UR crank pulley once the motor's out and get a G-spec crank pulley for the ve, unless people have used the de UR crank pulley with no issues on the ve.
  20. #19
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Quote Originally Posted by P10 Goodness View Post
    Awesome man. What do you have for engine/fuel management?
  21. #20
    Join Date
    Sep 2008
    Location
    Mesa, AZ
    Posts
    686
    Right now, I'm using an innovative motorsports wideband controller, the narrow band output I soldered into the ECU narrow band in. This is good enough for a pretty accurate AFR (averages 14.2 ish) If I had a laptop with a SCSI input I'd set it a little richer (you can define what the narrow band output reads).
    In a couple weeks I'm getting my tax return, then I'ma go with a Nistune daughter board and software.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
