G20.net - Forums
Go Back   G20.net - Forums > G20 Topics > Maintenance
Reply
Thread Tools Display Modes
Old Jun 02, 06, 09:08 AM   #1
Kazmi
G20 Guru
Kazmi's Avatar
Feedback: (0) (0%)
Vehicle: 08 DeepBlack B6
Question p10 driver's side window motor just quit
It rained a shit load yesterday and at the drivethru, my driver's side window would not come up until I basically pulled it up while pulling on the switch.....I'm guessing that my motor is shot to hell ......it works ok on bright sunny days but acts up in winter and esp during the rain - what an attitude....
I read the previous posts and it seems that the 94 Altima window motor drops right in and works alright for our Gs....any one try that? also, please refer a good source where to get a window motor from without having to sell one of my kidneys for it.....
Thanks as usual...
Kazmi is offline   Reply With Quote
Old Jun 03, 06, 06:23 AM   #2
Kazmi
G20 Guru
Kazmi's Avatar
Feedback: (0) (0%)
anyone?
Old Jun 03, 06, 06:33 AM   #3
p10det
drunken master
p10det's Avatar
Feedback: (3) (100%)
Vehicle: g20/94 turbo
not sure where to get one cheep. Be sure to inspect the regulator and lube as needed.
I can only say that a hand full of nissan window motors look identical
p10det is online now   Reply With Quote
Old Jun 03, 06, 10:10 AM   #4
davemac
G20 Member
Feedback: (0) (0%)
Vehicle: 1993.5 G20
ebay or car-part.com for used and you might get lucky. partsamerica.com you can get a reman motor and regulator for $110
davemac is offline   Reply With Quote
Old Jun 03, 06, 10:13 AM   #5
davemac
G20 Member
Feedback: (0) (0%)
Vehicle: 1993.5 G20
Strike that. It doesn't include the regulator, just motor for $110. http://www.partsamerica.com/ProductD...e=1326&ptset=A
I've got a good condition regulator for front driver you can have for shipping cost. Though you may be able to clean yours up and it will work fine with a new motor.
Old Jun 03, 06, 06:35 PM   #6
randyo156
#1 cop hater
randyo156's Avatar
Feedback: (2) (100%)
Vehicle: Down to 1 G
Kazmi
the windoww sticks to the rubber when its wet
mine are slow when they are wet
randyo156 is offline   Reply With Quote
Old Jun 04, 06, 12:20 AM   #7
reyesjnj
G20 Member
reyesjnj's Avatar
Feedback: (9) (100%)
Vehicle: 93p10 94p10t
its the window regulator inside the panel the little tan box i had the same problem i just went to a pick and pull....... junk yards
reyesjnj is offline   Reply With Quote
Old Jun 04, 06, 09:13 AM   #8
p10det
drunken master
p10det's Avatar
the regulator is not at all a box. Their is a amp box only on the drivers side as i remember
Old Jun 13, 06, 06:25 PM   #9
StreetRacerCA
G20 Newbie
Feedback: (0) (0%)
Vehicle: P10 1,6 16V
mine r slow 2 when they r wet, and wont shut down. lil tip dont open them when its rainig lol jk.
StreetRacerCA is offline   Reply With Quote
Old Jun 13, 06, 07:59 PM   #10
p10socal
G20 Senior Member
p10socal's Avatar
Feedback: (1) (100%)
Vehicle: p10
common problem
this is a common problem with our old cars....Let the window dry really good and see if it operates more freely. If it does then your motor is getting weak.. Also if you could get a hold of the window amp get it and see if that helps. I have tons of experience with this problem. I probably changed that regulator and motor 3 or 4 times due to buying used parts. and if your window is stuck at a postion where you cant unbolt the window, then i will be sure to include you into my prayers...good luck...check ebay...
__________________
91 p10 ..my primera has 262,000 miles now. salamat~gracias~laterz
(p10=beater car) my p10 is not only an old car, its an old friend that i cant get rid of!
Don't Hate just FORNICATE!
my race vid!
p10socal is offline   Reply With Quote
Old Jun 13, 06, 10:41 PM   #11
junknstuff
no rainguard clips...FML
junknstuff's Avatar
Feedback: (12) (100%)
Vehicle: 1992 KH2 P10
^^ lol yea i'll keep you in my prayers too
mine are slow but work alright still. if i find some extra cash, and if it really bothers me, i'll probably get some new motors for the driver and passenger sides to compete with the speeds of the new car windows
junknstuff is offline   Reply With Quote
Old Jun 14, 06, 07:53 AM   #12
Kazmi
G20 Guru
Kazmi's Avatar
Feedback: (0) (0%)
lol yea, it wasn't too funny when it was pouring out you guys...
but now that it's been dry for a couple of days, the window works fine ( not as fast or smooth as a new one but like it used to when I got her).....might look into cleaning the regulator or getting a new one if I can find some spare cash under the mattress...
Old Jun 14, 06, 08:17 AM   #13
kaiseiken
G20 Member
kaiseiken's Avatar
Feedback: (10) (100%)
Vehicle: 1996 G20
I had the same problem with my passenger window. Grease up the rear rubber window seal (closest to the back of the car) so that the glass doesn't stick to it on the way up.
Pull off the door panel and use some WD40 on the mechanism that slides up and down that center rail (window regulator?). Mine rusted a bit so I had to use a lot of WD40.
This procedure had all of my windows moving like new (about 4 seconds from bottom to top).
kaiseiken is offline   Reply With Quote
Old Jun 14, 06, 09:24 AM   #14
dekser
G20 Junior Member
dekser's Avatar
Feedback: (0) (0%)
Vehicle: S13
my pass side window gets slow in rain or severe humidity, which is common in miami. i pulled the motor and regulator, replaced with a known working one and it still friggen happens..got stuck down in the rain (at the metro station luckily) i had to tear the door apart to get it back up. i think i have a spare working motor separated from the regulator, its for the rear pass though...i dont know if it would just mount on to the front driver regulator, but i dont see any reason why nissan would have made different motors for each regulator.
dekser is offline   Reply With Quote
Old Jun 20, 06, 03:28 AM   #15
apexi240sxg20
G20 Newbie
apexi240sxg20's Avatar
Feedback: (0) (0%)
Vehicle: B14 SE-R/S13 SR
yea i have the same problem as well, when it rains the windows dont go up, i have to pull on them while im on the switch, but something happened today, (its hot and dry here in CA) the drivers window just wont go up anymore... the switch works, i can hear it clicking but it wont go up even when im pulling on the window!! is the motor completely shot??
apexi240sxg20 is offline   Reply With Quote
Old Jun 20, 06, 11:50 AM   #16
junknstuff
junknstuff's Avatar
or possibly its no longer connected to the bar? pop open that door panel and check it out. very easy to do
Old Sep 15, 06, 05:49 PM   #17
majx
G20 Newbie
Feedback: (0) (0%)
Vehicle: 1995 G20
I talked to a Mechanic about this and he said the G20 was notorious for doing this. He said you have to lubracate the window tracks with some sylicon lubricant. I had the same problem, especially when it turned cold but it now works with his suggestion.
majx is offline   Reply With Quote
Old Sep 16, 06, 08:09 AM   #18
davemac
G20 Member
Feedback: (0) (0%)
Vehicle: 1993.5 G20
On the rubber / felt window tracks spray silicone lubricant is the best stuff to use. On the regulator if you use anything spray white lithium grease is the best. WD40 will thin the grease that is there and is easily washed away by water, so not the best choice.
90s Nissan products for some reason do seem to be a weaker power window design. Weak motors and bad regulators is a pretty common problem. I have a couple old Toyotas and never had power window problems.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2007 G20.net
Smilies are copyright © 2002 Dark Project Studios
