G20.net - Forums
Go Back   G20.net - Forums > G20 Topics > Engine/Transmission
Reply
Thread Tools Display Modes
Old Dec 15, 02, 01:32 PM   #1
jbloggs_c
G20 Guru
Feedback: (0) (0%)
Vehicle: 05 Corolla S
what does a bad motor mount look like?
how do you spot a bad motor mount?
jbloggs_c is offline   Reply With Quote
Old Dec 15, 02, 01:43 PM   #2
Chris
Laid off 10/14/08
Chris's Avatar
Feedback: (60) (100%)
Vehicle: POS 95 g20t MT
well..
it usually has a nasty crack in it!
Chris is offline   Reply With Quote
Old Dec 15, 02, 10:52 PM   #3
CaptainMorgan
Registered User
Feedback: (0) (0%)
Vehicle: 1993 G20
good question....
Lets see....what does a bad motor mount look like????
Well, it probably has not shaved in awhile, has dirty clothes, and will stare at you each time you want by it and say, "What the Fock you lookin at!", not to mention the numerous prior "run-ins" with law enforcement and JV halls....It is my advice that you stay clear of the above, and get yourself some nice red Place Racing motor mounts, they are sweet and cluddley, and will always be there for you, even when your engine is not.
CaptainMorgan is offline   Reply With Quote
Old Dec 16, 02, 11:44 AM   #4
CarloSR
G20.net Staff
Mod on Occasion
CarloSR's Avatar
Feedback: (0) (0%)
Vehicle: ER34
You donīt see a bad motor mount you feel it.
__________________
CarloSR is offline   Reply With Quote
Old Dec 16, 02, 02:20 PM   #5
MR. RYTE
G20 Guru
MR. RYTE's Avatar
Feedback: (0) (0%)
Vehicle: Dark Green 95 G
Quote:
Precisely. You'll feel a helluvalot more vibration when you're idling. As for visual signs, as mentioned above, it has a crack in it and when you start the engine, it'll shake real bad.
__________________
Real name:Howard Wright
Current mods:S3 cams, TopSpeed header, M3-style rear wing, P11 rims, Recaro LS-L seats, Pioneer DEH-P6800MP CD/MP3 head unit w/6.5" Audiobahn AS65Q all around
THOU SHALT NOT MOD THAT WHICH THY CANNOT MAINTAIN" -thus speaketh Mr. Ryte
MR. RYTE is offline   Reply With Quote
Old Dec 16, 02, 02:53 PM   #6
Fraychild
G20 Guru
Fraychild's Avatar
Feedback: (0) (0%)
Vehicle: Mystery Machine
Talking he he
It'll shake... it'll shake when you shift_ (Nissan style), it'll shake when you idle, it'll shake when you go 'zoom-zoom-zoom'... (oops that's Mazda)...
You can see the cracks too in the rubber part... If you have bad ones... trust me, you wanna change them... Your car will feel like a brand new one
__________________
ミステリー機械<-- Click it, you know you wanna'...
NYCGs to the end!
Fraychild is offline   Reply With Quote
Old Dec 16, 02, 04:28 PM   #7
jbloggs_c
G20 Guru
Feedback: (0) (0%)
I'm getting a little of that jumping back in the shifter when i put it in gear or change gears or whatever but there isnt that much vibration. I guess they have a little longer left in them still. Is the shifter jumping around anything to worry about?
Old Dec 16, 02, 04:31 PM   #8
tdog551
G20 Guru
Feedback: (0) (0%)
Vehicle: 92 G
A guy i met with a det swapped into his sentra asked if i had movement in my stick when i put it into gear (like lateral movement while it's in gear), is that what you mean or do you mean the engine moves while in gear? he also said there was a recall on the sr20 shifter bearings or something like that, is this true?
tdog551 is offline   Reply With Quote
Old Dec 16, 02, 06:42 PM   #9
95G20
G20 Junior Member
Feedback: (0) (0%)
Vehicle: 95 G20
ive always wondered too about that, mostly when im in 3rd and 4th gear when i touch the gas the stick will move back and forth an inch or 2. Is that just the mounts?
95G20 is offline   Reply With Quote
Old Dec 16, 02, 07:10 PM   #10
CarloSR
G20.net Staff
Mod on Occasion
CarloSR's Avatar
Feedback: (0) (0%)
Vehicle: ER34
Quote:
Maybe you should look the trans mounts and inserts.
Quote:
You feel the engines vibs
Quote:
Thatīll be Ok at full gas
__________________
Old Dec 16, 02, 11:16 PM   #11
djisg20
G20 Member
Feedback: (0) (0%)
Vehicle: Nissan G20 1992
The movement of the stick when you touch the gas is due to the fact that the shift linkage clamps on the transmission for stability while another arm's duty is to change gears.
Stock motor mounts allow little engine movement in the engine bay to increase comforts and reduce vibration. If you've every look at the stock dog bone on your sr20de, you'll see it's webbed design and creates a lot of engine movement because of this design.
On my NX2000, I have polyurethane motor mounts inserts and there's absolutely no movement don't there, you can't even see it move and you don't feel it moving with the stick.
Answer: polyurethane!
djisg20 is offline   Reply With Quote
Old Dec 17, 02, 06:03 AM   #12
CarloSR
G20.net Staff
Mod on Occasion
CarloSR's Avatar
Feedback: (0) (0%)
Vehicle: ER34
Quote:
Where you got those?
__________________
Old Dec 17, 02, 10:48 PM   #13
djisg20
G20 Member
Feedback: (0) (0%)
Mine are inserts from Energy Suspension and you can get them online at courtesy Nissan (the ones for the B13 SE-R) for 70$.
I better like to put inserts than paying 250$ for the same thing from JWT!
Old Dec 18, 02, 12:38 PM   #14
jbloggs_c
G20 Guru
Feedback: (0) (0%)
Mine moves much less than an inch or 2 but its noticeable. Is that whole shift linkage thing going to cause any problems? I want to prevent 5th gear popout from developing if at all possible. I dont know if its related or not...
Old Dec 19, 02, 12:12 AM   #15
djisg20
G20 Member
Feedback: (0) (0%)
No it's not related. The engine movement in this engine bay is more critical for halfshafts because it prevents wheel hoping and tranny case cracking.
Old Dec 20, 02, 02:22 PM   #16
peachbel
G20 Newbie
Feedback: (0) (0%)
Vehicle: 95 G20 Black Emerald "Gessi"
I can't help myself - I have to share with you all b/c this just happened to my car...
One of the motor mounts was about to go, and I knew this because my car turned into to World's Largest Moving Vibrator. It would shake, rattle, and roll all at the same time, and after a trip out of state it obviously got worse. So my sister, going to school to become an automotive engineer, replaces the motor mount that went bad for me. When she showed me the old one, I said (no kidding!), "That thing looks like an inverted nipple! No wonder it felt so bad!"
I hope you have fun when you replace yours!
peachbel is offline   Reply With Quote
Old Nov 03, 09, 10:34 AM   #17
burubuduy
G20 Guru
burubuduy's Avatar
Feedback: (16) (100%)
Vehicle: Pay 11.99
out from the dead. but where is the cheap place to buy new OEM motor mounts?
__________________
burubuduy is offline   Reply With Quote
Old Nov 03, 09, 10:42 AM   #18
p10der
G20 Member
Feedback: (0) (0%)
Vehicle: 1991 G20
The junkyard. got my passenger mount for $5 it was brand new all clean like and the rubber was goood. id check there. but ebay usually has some good deals about $30 a piece
p10der is offline   Reply With Quote
Old Nov 03, 09, 01:15 PM   #19
Dane
scimp'n on my pimp'n
Dane's Avatar
Feedback: (18) (100%)
Vehicle: 95 G20t
Hockey pucks son. I've had mine in there for two and a half years and stll going strong. The P11 is even easier because the front and rear mounts are the same.
Dane is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2007 G20.net
Smilies are copyright © 2002 Dark Project Studios
