G20.net - Forums
Go Back   G20.net - Forums > G20 Topics > Cosmetics
Reply
Thread Tools Display Modes
Old May 27, 08, 05:20 AM   #61
kaiseiken
G20 Member
kaiseiken's Avatar
Feedback: (10) (100%)
Vehicle: 1996 G20
Quote:
Originally Posted by jrm View Post
i picked up 4 washers, but the car is still on the lift while I do my tranny- will post results asap, BTW my door drops 1 inch and no longer closes without picking it up- do you think 2 washers on each bolt is enough?
I'm not sure, take pictures and post results. It depends on how thick the washers are.
After you install the washers, the entire door is closer to the b-pillar. It is possible that if the top hinge were worn too much that the washers would position the door so that it couldn't close (it would hit the back door). I've never seen that happen though...
kaiseiken is offline   Reply With Quote
Old May 27, 08, 08:38 AM   #62
mattb
G20 Guru
mattb's Avatar
Feedback: (1) (100%)
Vehicle: 2001 I30 Luxury
This seems to be a common problem on a lot of Nissans...the Maxima/I30/I35 are prone to this too.
mattb is offline   Reply With Quote
Old May 27, 08, 09:01 AM   #63
Koojo
Koojo...Doctor Koojo..
Koojo's Avatar
Feedback: (6) (100%)
Vehicle: 2000 G20 Turbo
Hinges for sure. My P10 needed them
Koojo is offline   Reply With Quote
Old Sep 13, 08, 12:03 AM   #64
Dane
scimp'n on my pimp'n
Dane's Avatar
Feedback: (19) (100%)
Vehicle: 95 G20t, 93G20
I picked up two 1/16 inch thick washers and put them between the lower door hinge, one on each bolt. I've had the washers in the car for six months, but have just be either to busy or to lazy to get it done. All it took was a 12mm wrench and thirty seconds. This fixed the problem I've had with sagging door hinges. I've put up with it for years and I decided today was the day. It worked perfectly the door lines up great it even up the gap between the door and fender.
If anyone has saggy doors I highly recommend this 32 cent fix.
__________________
Quote:
Originally Posted by Blackwater32 View Post
Someone quote me.
Dane is offline   Reply With Quote
Old Sep 13, 08, 12:10 AM   #65
g20honey
G20 Member
Feedback: (0) (0%)
Vehicle: 93 DET
I went with the even cheaper route and jacked up my doors and re-tightened down the bolts. Worked like a charm
g20honey is offline   Reply With Quote
Old Sep 13, 08, 12:11 AM   #66
Straitup D
Automotive Design Concept
Straitup D's Avatar
Feedback: (24) (100%)
Vehicle: Swedish Fish
koooo i will have to try this with my boi's s-10 blazer
Straitup D is offline   Reply With Quote
Old Sep 13, 08, 12:15 AM   #67
Dane
Dane's Avatar
Not so fast. Most old Chevy's have the hinge welded to the body, well my K30 and my parents suburban are welded. If that is the case you can go to any auto parts store and buy a hinge rebuild kit. It is usually a bushing and a new pin.
__________________
Someone quote me.
Old Apr 04, 09, 11:16 AM   #68
Crazy4myP10
G20 Guru
Feedback: (17) (100%)
Vehicle: 94G20T/99G20
BUMP! Thanks for the trick Dane. Worked like a charm. No more creaks and saggy doors for me!
Crazy4myP10 is offline   Reply With Quote
Old Apr 04, 09, 12:08 PM   #69
Dane
Dane's Avatar
Quote:
Awesome. The washers sure are better than having to install new hinges.
My bro also did this to his P10 as well.
__________________
Someone quote me.
Old Apr 04, 09, 12:14 PM   #70
Crazy4myP10
G20 Guru
Definitely cheap and effective!
Old Apr 17, 09, 02:34 PM   #71
p10socal
G20 Senior Member
p10socal's Avatar
Vehicle: p10
This should be in the HOW To section...
Did this mod to my p10 probably been sagging for the past decade. Now its like brand new. WOW well recommended!!! Thank You for helping my life!!
__________________
91 p10 ..my primera has 262,000 miles now. salamat~gracias~laterz
(p10=beater car) my p10 is not only an old car, its an old friend that i cant get rid of!
Don't Hate just FORNICATE!
my race vid!
p10socal is offline   Reply With Quote
Old Jun 17, 09, 05:40 PM   #72
smorris65
G20 Newbie
Feedback: (0) (0%)
Vehicle: none
Is there one or the other that usually goes bad (top or bottom)?
I only bought the lower thinking it was the one bad. Wondering if I need to order the top one and just do both at same time.
Let me know your thought's please.
smorris65 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2007 G20.net
Smilies are copyright © 2002 Dark Project Studios
