G20.net - Forums
Go Back   G20.net - Forums > G20 Topics > Member's Rides
Notices
Reply
Thread Tools Display Modes
Old Feb 22, 09, 05:57 PM   #1
thefultonhow
Used to own a P10
thefultonhow's Avatar
Feedback: (10) (100%)
Vehicle: 05 Legacy GT
thefultonhow's 1992 CH0 P10
I've done a lot of stuff already, but I thought I'd make a progress thread before I got TOO serious.
http://www.g20.net/forum/showthread.php?t=84721
Mods:
  • Engine: http://www.g20.net/forum/showthread.php?t=82739 (2008), JWT Pop-Charger (2009), ASP "budget" header (2009), custom 2.5" exhaust (with Dynomax VT offset/offset muffler, Magnaflow 22" resonator, Mandrel Exhaust Systems piping, Magnaflow 2.5" cat) (2010), SR16VE N1 cams with Custom Steel adjustable cam gears (2009), Granatelli dual-output RPM window switch (2009)
  • Drivetrain: B13 LSD manual transmission (2010), JWT pressure plate and B15 clutch disk (2010), Fidanza flywheel (2009)
  • Interior/Audio/Security: Alpine CDE-9852 with iPod integration (2006), Phoenix Gold RSd 6.5" component door speakers (2009), Custom installation of 2003 Nissan Maxima keyless entry system (2009), manual seatbelts (2007), seats from 1995 G20 with mappockets and rear headrests (2009)
  • Suspension/Brakes: KYB AGX shocks with newer P11 front springs (2009), P11 front brakes with EBC Greenstuff pads front/rear (2009)
  • Wheels/Tires: P11 mesh wheels (2009) with BFGoodrich g-Force Super Sport A/S all-season tires (2010; less than 5000 mi)
Not installed:
  • OEM fog lights
OEM parts that have been replaced on this car (due to failure of the original part) since I got it in 2006:
  • Engine (August 2006)
  • Transmission (December 2008, August 2010)
  • Clutch (August 2006, June 2010, August 2010)
  • Rear engine mount (August 2006)
  • Exhaust system (August 2009)
  • AC compressor (May 2007)
  • AC high pressure line (November 2007)
  • AC receiver/dryer (November 2007)
  • Blower resistor (January 2007)
  • Alternator (June 2008)
  • Alternator harness (July 2009)
  • Battery (November 2006)
  • Starter (November 2006)
  • Drive belts (August 2009)
  • Radiator (August 2006)
  • Right axle (August 2006; August 2010)
  • Left axle (August 2008)
  • Front struts (December 2008)
  • Right rear brake caliper (April 2010)
  • Right front brake line (November 2008)
  • Left front brake line (April 2010)
  • Front pads and rotors (August 2006)
  • Front pads (November 2008)
  • Rear pads and rotors (December 2009)
  • Fuel tank vent line (May 2008)
  • Heater hose (December 2009)
  • Left and right fenders due to rust (August 2006)
thefultonhow is offline   Reply With Quote
Old Feb 22, 09, 05:58 PM   #2
thefultonhow
Used to own a P10
Pictures:
Old Feb 22, 09, 06:03 PM   #3
p10det
drunken master
p10det's Avatar
Feedback: (3) (100%)
Vehicle: g20/94 turbo
are you looking to dyno soon?
i can get you base lines for around 60$
on hub dyno. let me know.
p10det is offline   Reply With Quote
Old Feb 22, 09, 06:05 PM   #4
thefultonhow
Used to own a P10
I think I'll probably wait until summer. Money and time are both tight right now. But I will want to get a couple runs in when they're not as tight.
Old Feb 22, 09, 06:34 PM   #5
stuntzG20
3 Hole Bumper Guru
stuntzG20's Avatar
Feedback: (18) (100%)
Vehicle: ch0ve
Whats your game plan here...
way to start a progress thread so close to mine...
Just messing with ya, lol I like the progress.
__________________
Quote:
Originally Posted by 00 blk G20t View Post
stuntz started yelling on a megaphone.
Quote:
Originally Posted by Blackwater32 View Post
looks like he got his penis stuck in the air box again.
stuntzG20 is offline   Reply With Quote
Old Feb 22, 09, 06:39 PM   #6
thefultonhow
Used to own a P10
Just trying to steal your thunder!
Old Feb 22, 09, 06:44 PM   #7
p10det
drunken master
p10det's Avatar
man.I wanted to have a ve come in on the dyno. i also am wanting to see ya geet more than 160whp.
who cant aford 60$ plus you can post the dyno on the progress thread
oh well.
im going to start a tread soon on a qyno nd bbq meet and it will only cost 50$ if i can get like 8 peeps to do pulls.
im only going to dyno my car last if time allows just in case people want to see it in action. thats if the engine isnt removed and getting built are fresh build is not on brake in time
Old Feb 22, 09, 06:54 PM   #8
thefultonhow
Used to own a P10
If you want to do a dyno meet the weekend of March 21-22, I would probably be able to make it. I think I'll have more than 160whp, even with stock exhaust. Most people with VE/I/H/E are around 175-180whp, I think.
Old Feb 22, 09, 06:58 PM   #9
p10det
drunken master
p10det's Avatar
if interest is their i can prolly work something out. but im unsure if i can grab dedication by that time i will start a thread with in 24hours are less to see what happens. Cool ?
Old Feb 22, 09, 07:10 PM   #10
thefultonhow
Used to own a P10
Sounds good! That's my spring break, so I should be free.
Old Mar 25, 09, 08:40 PM   #11
thefultonhow
Used to own a P10
It's been a busy week.
Friday to Sunday: Installed the Maxima keyless entry.
Saturday: dyno meet up in Delaware. Dynoed 140whp, which is pretty low. Mike (p10det) thinks it's my exhaust, so I've added that to the list of upcoming mods.
Sunday: Got an alignment at Firestone (I sprang for the lifetime one). They failed at doing the left rear, so I had to go back on Monday again.
Monday: Took the Fidanza in to get the bolt holes fixed.
Tuesday: Picked up and installed the Fidanza. It was a seriously taxing job. I had the transmission off in two hours, but then I had a lot of trouble getting it back on. I started at 4pm and finished up at 2am.
Wednesday (today): Fixed a few things I hadn't before from my Fidanza install. Sprung a huge coolant leak from the heater hose (now fixed) and a huge exhaust leak from the SSAC flexpipe (not yet fixed). Also got Yokohama S.drives mounted on my Sport rims and the rims installed on the car. The people doing the tires fixed the left rear wheel alignment again, too (Firestone really does fail).
Thursday (tomorrow) to Sunday: SR2009!
Old Mar 25, 09, 09:23 PM   #12
vinceoftexas
G20 Member
vinceoftexas's Avatar
Feedback: (0) (0%)
Vehicle: 99 JV0 g20t
that p10 is sick.
that engine/engine bay is super clean.
looks great
vinceoftexas is offline   Reply With Quote
Old Mar 26, 09, 08:34 AM   #13
G20 Zelman
G20 Member
G20 Zelman's Avatar
Feedback: (1) (100%)
Vehicle: '96 DP0 5 Speed
I love what you've got done on this thing, but I'm surprised I don't see anything regarding an intake in your past or future. It just seemed like the first thing to do for most people. "Hm. I got a car... What now? Intake I guess..." Like that. Any particular reason for the lack of interest?
__________________
Better to remain silent and be thought a fool than to speak out and remove all doubt. -Abraham Lincoln
G20 Zelman is offline   Reply With Quote
Old Mar 26, 09, 09:43 AM   #14
gotboost44
G20 Guru
gotboost44's Avatar
Vehicle: p10/Cayenne S
I love it..
and I do love the fact that you left the factory airbox and kept in practical. its the best way to have a DD.
gotboost44 is offline   Reply With Quote
Old Mar 26, 09, 10:05 AM   #15
Robj80
stock rocks!
Robj80's Avatar
Feedback: (31) (100%)
Vehicle: p11 & C11 yes C
I been trying to find away to route my intake from the turbo to a factory air box. I can't stand the noise, cleaning or the sloppiness of a filter dangling off the end of a pipe.
Car looks great.
Robj80 is online now   Reply With Quote
Old Mar 26, 09, 10:11 AM   #16
mh64
Internet Mechanic
mh64's Avatar
Feedback: (20) (100%)
Vehicle: '01 G20,'95 G20
looks even better in person!
__________________
Quote:
Originally Posted by enohand
so mike you wanna help me do this tranny?
UPDATE COMING SOON
Teaser for now, update will be here once i get some things back from paint!
mh64 is offline   Reply With Quote
Old Mar 26, 09, 09:23 PM   #17
thefultonhow
Used to own a P10
I actually only have the top of my factory airbox. The bottom wouldn't fit with the VE -- the intake tube was at the wrong angle. So it's essentially a WAI, because it's just got the panel filter taped to the top.
I discovered what my leak in my SSAC is (well, someone else at SR2009 did)... It's just the EGR plug. It came unscrewed and blew out. So that should be an easy fix.
Old Jul 24, 09, 01:34 PM   #18
thefultonhow
Used to own a P10
I now have P11 mechies with Falken Ziex ZE912 to keep the wear off my Sport wheels and S.Drives, a JWT Pop Charger to replace my ghetto WAI, and an ASP header to replace the eBay header. Exhaust is coming next -- I'm planning on ordering the parts this afternoon.
Old Jul 24, 09, 02:05 PM   #19
P11Gdub
Sunnyvale Trailer Park
P11Gdub's Avatar
Feedback: (81) (100%)
Vehicle: Pee11 / pooP10
Quote:
i prefer the meshies on P10s. how is the ASP header feeling? what options did you get on it?
__________________
THE ARTIST FORMERLY KNOWN AS MR. SEOUL
Curts like the 1st aunt Vivian from Fresh Prince and im like the 2nd aunt Vivian
WTB: '99 AC compressor
P11Gdub is offline   Reply With Quote
Old Jul 24, 09, 02:08 PM   #20
thefultonhow
Used to own a P10
Quote:
Yeah, the meshies look really good on P10s. There's something up with my throttle cable and I have an exhaust leak somewhere in the header area, so I'm reserving judgement until I fix those two problems. The header has the V-band, and maybe the full merge collectors? I bought KwikyMAN's from the second GB, so I'm not sure exactly what options he got and/or what was included in the second GB.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2007 G20.net
Smilies are copyright © 2002 Dark Project Studios
