#1 |
G20 Newbie
Power window funkyness
Hello guys,
Ok so the front passenger side window can only be controlled by the driver side switch. Does the switch need to be replaced or cleaned or is there a fuse specifically for that switch that would need to be replaced? I searched already and nothing really answered the issue I had. Thanks |
#5 |
Highport FTW!!
Feedback: (15) (100%)
Vehicle: 1999 G20 M/T!!
raid the junkyards. they'll sell em to you for around $10 or so dollars. getting the new switch should fix the problem. if you can still roll the window up and down from the driver's side, then we know that the motor works. so the problem is in the switch on the passenger side
#7 |
G20 Member
i have a 91 P10 .....the passenger side door does not have a switch to roll the window down, so i went to the junkyard and found a switch from a 95 P10.....but when i took the passenger door panel off to locate the plug to connect the switch ....it wasn't there...is this normal or do i have a abnormal car? I can only control the passenger side window via the center console.
#9 |
G20 Member
| Thread Tools | |
| Display Modes | |
