#1 |
THAT f'ing guy...
G20.net Administrator
Feedback: (12) (100%)
Vehicle: SR20VE '95 P10
Featured Member of the Month - August 2009
Sean's (gotboost44) 1991 Infiniti G20 ![]() click image(s) to enlarge G20.net: How, when & why did you first acquire your Infiniti G20? gotboost44: I bought my p10 back in May of 2003 from some old lady that lived a few miles from me. At this time I was looking for a dependable daily driver that I could drive between home, school, and work. It was one of the best purchases I have ever made. I bought the car for $3,800 and it only had 54,000 miles on it. She also never drove the car in winter and it was immaculate. ![]() click image(s) to enlarge G20.net: What were your original plans for the car and have they changed? gotboost44: Originally my plans for the car where not anything special. My whole life I have been involved in one form of racing or another and the p10 was no more than a daily driver to me. I wanted to upgrade the stereo and throw a basic suspension and wheels on it and call it a day. Well needless to say those plans didn’t really change as much as I found it hard to stop after that. Next thing you know I’m doing a manual transmission swap and adding a fresh DET to the mix. ![]() click image(s) to enlarge G20.net: What performance modifications have you made to your car? gotboost44: Currently I have a W10 SR20DET with a GTiR T28 for a turbo. Im back to the stock high port cams again as I can’t seem to find an aftermarket cam I’m happy with for autocross. For the exhaust I have a hand built 3” turbo back system with a 36” resonator under the center of the car and a chambered muffler in the rear. For the intake I have the turbo hooked up to the Z32 MAF via 3.5” piping. Currently I’m only running 370cc injectors at 4 bar and I can put out more power than they can handle. The ECU control is a basic Calum tune that is fine tuned by my Emanage, Innovate motorsport wideband, and a Gizzmo electronic boost controller. The driveline consists of a b13 SER transmission that I hand built, and its all held up by Prothane engine mounts that I turned custom sleeves for. There are a lot of other little things I have done but the list would go on forever. ![]() click image(s) to enlarge G20.net: Do you have any dyno numbers? gotboost44: I have no recent dyno numbers that would reflect my current set up. But Since I have found the limit of the 370cc injectors at 4 bar I would have to say im right around 300hp the wheels. I have gone higher with boost with this set up (about 22psi) but the injectors where at 100% duty cycle and my engine started to lean out. ![]() click image(s) to enlarge G20.net: What suspension modifications have you made to the car? gotboost44: Currently I’m running Tein springs wrapped around GR-2 shocks. I have replaced my upper links stock bushings with a custom turned pivot shafts which sits in super pro bushings. In the rear I have installed an Addco sway bar. I have a couple sets of wheels to go along with it, I use a pair of 15” with Azenis for autocross and another set of 16” wheels for on the street. ![]() click image(s) to enlarge G20.net: Any cosmetic modifications to the exterior? gotboost44: Well I cut out the center bar in the front grill, debadged the car, carbon fiber hood, and sunroof delete. I have always liked the look of having more of a sleeper. The one mod that will be doing in the future though is adding a factory rear spoiler. I got the chance for the first time to follow my car as someone else drove it and I realized that the rear end looks pretty blah and its needs a little more spice. ![]() click image(s) to enlarge G20.net: How about the interior? gotboost44: Actually right before this I was running no interior. All I really had was the dash and door skins on. But with recent developments and me changing classes with autocross I had no choice but to put some of it back in, which I actually just finished up for the photo shoot. SCCA permits me to remove some items with my class so I don’t have A/C in the car, a radio, and the trunk has nothing in it. I have gained a new smaller steering wheel, racing seat, harness, and some gauges so I can watch my vitals at track days. ![]() click image(s) to enlarge G20.net: Have you made any upgrades to the stock sound system? gotboost44: I no longer have a stereo or speakers in the car. They have been replaced by a gauge cluster and some switches. ![]() click image(s) to enlarge G20.net: Any future modifications we should look out for? gotboost44: Engine wise I’m not going to do much more as the power is ridiculous as it is. I will be looking to slap on some bigger injectors and switching over to a newer Garret GT28 that has a roller bearing. I also might throw in some C series cams to rev higher. I will be redoing my entire suspension this next winter. I’m finding that at races I have reached the limit and it’s time to move to the next level. I will defiantly be installing an advanced adjustable coil over setup, but I have not made up my mind on exactly what yet. I will be upgrading my master cylinder to a 1” unit and run some different race pads. Also next year I will start to run A6 Hoosiers. And as some of you know I have a problem keeping transmissions in the car, so a B15 or p11 transmission is on the way. ![]() click image(s) to enlarge G20.net: How and when did you first find G20.net? gotboost44: I found G20.net when I first started to modify the suspension and stereo in the car a couple months after I bought it. However I really didn’t become a member until the power bug bit me in the butt. ![]() click image(s) to enlarge G20.net: How has this site benefited you? gotboost44: It has helped me with getting my project car done to where I like it as well as increase my general mechanical knowledge. It’s a place where I feel comfortable asking technical questions and actually getting an informative answer. G20.net also has served as a good way to kill time when I’m bored and/or don’t feel like working. Haha.. ![]() click image(s) to enlarge G20.net: Any last comments you would like to make? gotboost44: Thanks to everyone that has helped me out over the years and I hope that I can help continue to make the forum a place where people can come for answers and learn through other people’s experience. ![]() click image(s) to enlarge gotboost44: Also I would like to comment that Zohaib is a failure at life :-)
__________________
- j0n |
#2 |
I <3 p10's
Feedback: (14) (100%)
Vehicle: p10 machine
Car looks so clean. I like the din gauges, and switches.
__________________
![]() p10t + trout= "come on legs, come on run/ come on knees, don't be mean/ come on knees, cause that ain't the first red you've ever seen/ come on feet, do ya thang/don't cop out on me/don't give in on me/come on legs, come on cruise for me" |
#4 |
Dude, your bed is a car..
Woot Woot!!!
Congrats bro! I've seen the car in person and it looks great...
__________________
![]() Electric supercharger, Cross Drilled Brake Lines, Muffler Bearing, custom O Pipe Single Exhaust system, Racing rotary engine pistons, Ebay speed chip, flux capacitor, spring free struts, KaleCoAuto Lowering Kit...etc. No, I don't have any of the listed parts. some are not even real so no more PM's please
#12 |
It's your MAF....
Congrats
__________________
How To: X-Member Mounts! | Common problems/diagnosis thread | My Feedback Thread 99 KR4 P11 5MT | 01 KV3 A33 Maxima 5MT |
#17 |
Colts > Patriots
Feedback: (64) (100%)
Vehicle: AR2-D2 HP11t
congrats! i've always liked your clean ass P10.
#18 |
Full-Time Chiller . . . .
Feedback: (34) (100%)
Vehicle: Saab 9-5 Aero
Congrats
__________________
May 2008 MOTM Tons of 99-02 Parts for sale: http://www.g20.net/forum/showthread.php?p=1123141 Tons of 91-96 parts for sale: http://www.g20.net/forum/showthread.php?t=85762 Check out my T-Shirt company, funny/quality shirts: www.ratfinktshirts.com Code jesp414 saves you $3 per shirt. |
| Thread Tools | |
| Display Modes | |
