G20.net - Forums
Go Back   G20.net - Forums > G20 Topics > Wheels/Suspension
Reply
Thread Tools Display Modes
Old Sep 03, 09, 08:46 PM   #1
roblop04
G20 Member
roblop04's Avatar
Feedback: (8) (100%)
Vehicle: 95 B14 SER
SPEC-V Brakes on G20?
Well I have a friend that has a Spec-V that has a spare of front and rear calipers with rotors and pads.. and i was wondering if that brake setup is better than the ones on a G20 and if it is would they fit on our car with out any mod??
roblop04 is offline   Reply With Quote
Old Sep 04, 09, 01:30 AM   #2
eugeneg20
G20 Senior Member
Feedback: (0) (0%)
Vehicle: 1994 & 1992 g20
if they are the brembos then its a direct bolt on and will give you better stopping power, there are many people on here that have done so
eugeneg20 is offline   Reply With Quote
Old Sep 04, 09, 07:12 AM   #3
Chris
Laid off 10/14/08
Chris's Avatar
Feedback: (60) (100%)
Vehicle: POS 95 g20t MT
...just keep in mind that the brembo brake upgrade means you've just limited your wheel choices as well. (you can never go back to 15" wheels much less 14" and so far I've only seen 1 set of unique 16s that fit and even most 17s won't work )
Chris is online now   Reply With Quote
Old Sep 04, 09, 07:23 AM   #4
roblop04
G20 Member
roblop04's Avatar
Vehicle: 95 B14 SER
i have the g20 sport rims.. now.. are the brembo brake set up the ones that come originaly on the spec-v??
Old Sep 04, 09, 07:33 AM   #5
Chris
Laid off 10/14/08
Chris's Avatar
Quote:
Brembo brakes were not available on the 2002 or 2003 SpecV and did not appear until 2004 SpecV
I'm not the authority on SpecV though so I don't know if it was a standard SpecV thing starting with 2004 or an option so I'm sure someone else can chime in.
The brembo option is very obvious though FWIW. They will be gold calipers with BREMBO imprinted right on them for the front (the rear are not brembo IIRC)
Old Sep 04, 09, 07:35 AM   #6
Chris
Laid off 10/14/08
Chris's Avatar
..AND although the rear is slightly different, my understanding is the rear upgrade is only an option on the p11 and won't just bolt right onto the p10 (same reason why p11 rear brakes cannot just be installed on a p10 for example)
Old Sep 04, 09, 07:38 AM   #7
roblop04
G20 Member
roblop04's Avatar
Vehicle: 95 B14 SER
Since I have the G20 Sport rims.. then that brake setup would not fit correct??
Old Sep 04, 09, 07:41 AM   #8
Chris
Laid off 10/14/08
Chris's Avatar
incorrect
The g20 sport rims are only 16" and will NOT clear specV brembo brakes.
Like I said, I have only heard of 1 set of specialized rims in 16" to clear the specV brembo brakes.
You will need to find 17s (because my understanding of that 1 lone set of 16s that fit aren't even made any more and were a fluke/luck to find for that one person) -- you can do some searching here to try to find that post/thread (It MIGHT be on the brembo club thread but I don't remember). ..and BTW, NOT ALL 17s clear either so do your research before you buy!!! For example, the 17" factory 2002 or 2003 SpecV wheel does NOT clear the brembo specV brakes of 2004!!!!!
Old Sep 04, 09, 07:58 AM   #9
roblop04
G20 Member
roblop04's Avatar
Vehicle: 95 B14 SER
thanks chris.. and i just traded a set of 2004-2006 spec-v rims for the G20 sport.. I guess i have to look for another brake setup that would work on the Sport rims.. thanks again..
Old Sep 04, 09, 08:03 AM   #10
HockeyVG
G20 Member
HockeyVG's Avatar
Feedback: (2) (100%)
Vehicle: '94 Auto P10
The wilwood's do fit on the sport rims, right? If so, that may be an option for you.
I'm just guessing you want the free brakes from your friend instead
HockeyVG is online now   Reply With Quote
Old Sep 04, 09, 08:04 AM   #11
Chris
Laid off 10/14/08
Chris's Avatar
Thumbs up
DOH.. Yeah, those wheels would have worked...
You can always do the p11 brake upgrade (cheapest, fastest, easiest without even touching the calipers -- just change rotors, carriers and pads and improve the braking on the p10!)
OR are you talking about a p11 in the first place?
Old Sep 04, 09, 08:11 AM   #12
roblop04
G20 Member
roblop04's Avatar
Vehicle: 95 B14 SER
Sorry I forgot to mention I have a 99 P11T.... I did the trade because I like the Sport rims better...
Old Sep 04, 09, 08:13 AM   #13
Chris
Laid off 10/14/08
Chris's Avatar
okay, to improve braking, have you considered going SS Brake lines 1st? and improving the brake pads you are using (doing a full flush of the system and possibly upgrading brake fluid?)
You'd be surprised what SS brake lines can do for braking feel for example.
Old Sep 04, 09, 11:15 AM   #14
polg20
G20 Guru
polg20's Avatar
Feedback: (9) (100%)
Vehicle: RR pawah
Quote:
did not know that,
anyways what SS lines options do we have for p11? and what would be considered an upgrade in brakefluid ???
sorry to kinda jack the thread....
polg20 is offline   Reply With Quote
Old Sep 04, 09, 11:18 AM   #15
Chris
Laid off 10/14/08
Chris's Avatar
no worries.
It seems Techafit is the company to talk to about custom applications (see other brake-line thread here for details) and apparently the only company willing to work with g20 owners so far (goodridge wouldn't give us the time of day when I tried to get them to make modifications for better fitment for example)
and upgrade on brake fluid would be ATE gold or ATE super blue (good for up to 4 years in a street vehicle but only good for a few track events before needing to be bled in that application)
Old Sep 04, 09, 11:26 AM   #16
polg20
G20 Guru
polg20's Avatar
Vehicle: RR pawah
yeah ive missed that techafit GB by couple days, but there is a thread on a design flaw on those. any particular brand of fliud you can suggest?
Old Sep 04, 09, 11:46 AM   #17
Chris
Laid off 10/14/08
Chris's Avatar
ATE Gold or ATE Super Blue. www.ogracing.com sells it for $10.95 a bottle IIRC (that's what I would recommend for someone who want's to keep it in a street car for 2-4 years)
Old Sep 04, 09, 04:57 PM   #18
eugeneg20
G20 Senior Member
Feedback: (0) (0%)
so the 2002 and 2003 spec v rims fit both the p11 and p10 correct me if im wrong
Old Sep 04, 09, 05:09 PM   #19
Chris
Laid off 10/14/08
Chris's Avatar
Quote:
YES, the SpecV rims fit p10 and p11 fine.. BUT the 2002 and 2003 specV rims will NOT fit over the 2004+ specV Brembo brakes is what I was trying to get at.
Old Sep 04, 09, 05:36 PM   #20
Necraos606
G20 Member
Necraos606's Avatar
Vehicle: 96 P10
Those 16" that fit, are you talking about the Regamasters? I know a couple of other high dollar wheels (TE37, SSR Type-C both 16x8) that fit over brembos. Being forged and having small, thin spokes is always a plus.
If you REALLY wanna know what wheels fit, head over to the B15forums. They'd be glad to help you out.
Necraos606 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2007 G20.net
Smilies are copyright © 2002 Dark Project Studios
