G20.net - Forums
Go Back   G20.net - Forums > G20 Topics > Engine/Transmission
Reply
Thread Tools Display Modes
Old Oct 29, 09, 11:13 AM   #1
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
IACV = Meltdown
Well the famous p505 for the iacv code came up. Decided to find out what the issue was. Started taking it apart and couldn't get the plug off the iacv. Once I did get it off, it was clear to see that the pins inside the connector and the iacv melted together.
Here is a pic
So I bought a new iacv and replaced the connector. Put everything back together and the car started right up. However it had a high idle of 1500 rpm. Did the iacv relearn and nothing changed. So took everything apart and decided to diagnose the issue. The connector and the wiring was fine. The iacv was also fine. So decided to take a look at the ecu. Took it apart and found this.
It melted inside as well. The output resistor melted and it is the reason for the high idle.
Now the question comes to either replacing the ecu or solder a new resistor.
Just wanted to share....
vsamoylov is offline   Reply With Quote
Old Oct 29, 09, 11:15 AM   #2
Robj80
AKA robkris8079
Robj80's Avatar
Feedback: (12) (100%)
Vehicle: p10 & C11 yes C
man this is too common for me in the nissan world.
__________________
WTB p11 automatic in need of mechanical love, let me know what you got
Robj80 is offline   Reply With Quote
Old Oct 29, 09, 11:24 AM   #3
polg20
G20 Guru
polg20's Avatar
Feedback: (9) (100%)
Vehicle: RR pawah
damn, i heard of 00+ ECu going bad but never seen it, scary
__________________
There are no weapons of mass destruction in Iraq, Chuck Norris lives in Oklahoma.
polg20 is offline   Reply With Quote
Old Oct 29, 09, 01:06 PM   #4
bender-san
G20 Member
bender-san's Avatar
Feedback: (0) (0%)
Vehicle: 1995 G20t
This is extremely common in many Nissans (along with the electric engine mounts in the Maximas).
bender-san is offline   Reply With Quote
Old Nov 02, 09, 01:25 PM   #5
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
Never had any issues with maximas and I own 2 of them. The g20 has given me more problems and issues to diagnose and fix then the maximas.
Well I am now looking for an ecu now. Then have to tow the vehicle to get the key programmed to the new ecu. What A PITA.....
Old Nov 03, 09, 01:27 AM   #6
bender-san
G20 Member
bender-san's Avatar
Feedback: (0) (0%)
Vehicle: 1995 G20t
Quote:
Trust me...it's common. I've done dozens of ECM/IACV combo replacements.
Old Nov 03, 09, 01:46 AM   #7
Krist
Sponsored by BevMo!
Krist's Avatar
Vehicle: SRG20VE
I have a couple ECUs if you need one.
http://www.g20.net/forum/showthread.php?t=85103
__________________
We be clubbin'...
Brembo Club .............................. NeoVVL Club .............................. 5port Club .............................. Remus Club
Krist is offline   Reply With Quote
Old Nov 03, 09, 08:34 AM   #8
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
^^^ thanks. I need one from an 02 but auto
Old Nov 03, 09, 12:17 PM   #9
irishwrench
G20 Junior Member
Feedback: (2) (100%)
Vehicle: 2002 Sport
I have one. It was in my car before the 5speed swap with about 42K on it. Send me an offer. Don't forget it will require a key re-programm from the factory scan tool.
I need to buy a 5speed one since I just got the 505 code of death also. I have an 01 Maxima in my garage right now with a 505 code and the PCM is fried.
irishwrench is offline   Reply With Quote
Old Nov 03, 09, 12:29 PM   #10
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
^^^ pm sent
Old Nov 09, 09, 10:48 AM   #11
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
Well bought a ecu from a member on g20.net. By the way thanks. Tomorrow i will take the car to a local nissan dealer and have them program the key to the ecu.
Old Nov 10, 09, 08:17 AM   #12
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
Well I took the car to the dealer last night. I drove it there with the bad ecu and then swapped the ecu. Dropped the car off and they programmed the keys this morning. Car started up fine but had a high idle. I didnt want to mess again with the re-learn for the idle so I had the dealership do it for me.
Old Nov 10, 09, 06:36 PM   #13
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
FUCK this iacv BS... that is all...
Nissan programmed the keys to the car. I wanted them to do an idle re-learn and they failed. They updated the ecu firmware but for some reason could not get the idle to be normal. So the idle is still at 1500 rpm and the car bogs and drives weird under 2k rpm....
Old Nov 10, 09, 10:15 PM   #14
bender-san
G20 Member
bender-san's Avatar
Feedback: (0) (0%)
Vehicle: 1995 G20t
Bogging under 2k sounds like more than an IAVL problem.
Old Nov 10, 09, 10:28 PM   #15
bigzitta
G20 Newbie
Feedback: (0) (0%)
Vehicle: 2002 g20
I need an ECU for a 2002 auto trans g20 $100
bigzitta is offline   Reply With Quote
Old Nov 11, 09, 07:03 AM   #16
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
Quote:
I will look further into the issue when the weather gets better. But as of now the car has a pending p505 code and a stored p505 code. I looked at the FSM and the wiring diagram and the signal goes directly from the IACV to the ECU. So there is nothing in between. I already replaced the ecu because it melted and replaced the iacv ( used one might be bad ? ). I will re-check my wiring to make sure it is correct.
Old Nov 15, 09, 10:44 PM   #17
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
Well I fixed the idle. Now by looking at the tach, the idle is under 1k. Car starts up and idles fine when it's cold. Before it would hold idle at 1500rpm.
Now my next issue is it the fact the car seems to have a limiter between 1500rpm and 2k. I give it gas and rev it till that rpm and it keeps bouncing off till I give it more gas. When more gas is given, the car manages to rev Past it. Basically a hesitation.
Any ideas ? I swapped maf sensors and that did not fix the issue. I also swapped the tps and that did not fix the issue.
Now i am stumped...
Old Nov 18, 09, 01:14 PM   #18
bigzitta
G20 Newbie
Feedback: (0) (0%)
Vehicle: 2002 g20
I am having same issues call me 561-302-7847
Old Nov 18, 09, 01:17 PM   #19
Chris
Laid off 10/14/08
Chris's Avatar
Feedback: (60) (100%)
Vehicle: POS 95 g20t MT
wow that is just scary...
Chris is online now   Reply With Quote
Old Nov 18, 09, 02:49 PM   #20
vsamoylov
G20 Senior Member
Feedback: (2) (75%)
Vehicle: 2002 G20
Quote:
I got my issue figured out. I replaced the tps and then adjusted it per FSM and the car is back to normal now
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2007 G20.net
Smilies are copyright © 2002 Dark Project Studios
