G20.net - Forums
Go Back   G20.net - Forums > G20 Topics > Engine/Transmission
Reply
Thread Tools Display Modes
Old Nov 02, 09, 04:20 PM   #1
TransAmBand1t
G20 Newbie
Feedback: (0) (0%)
Vehicle: 84 Celica Supra
93 P10 Intake Camshaft help please
My cousin wrecked his 95 P10t a few weeks ago. This past week we went to Connecticut to look at a 93 G20 5 speed for $650. The guy advertised the car as having a bad oil pan and a timing chain that needed to be done but still had enough life left on it. We look at it , it seems nice then we talk down to $550. we went to crank the car but the battery was very low so it turned over slightly. Sounded a little odd, didnt pay much mind to it. So we get the title and paper work. This was Tuesday. We register the car Friday and then we head back up to Connecticut with our oil pan. Install the oil pan and a fresh battery. Had my cousin crank the car, sounded like it had no compression. Pop the oil cap off, and the intake cam isnt moving. So basically we got screwed.
Moving a long, we towed the car back to Queens Yesterday. Today we popped the valve cover off and look a look. Behind the intake sprocket theres a crack on the cam. But from the looks of it, it looks like the sprocket is stripped and it sint grabbing the cam. From the looks of the intake cam, it seems like it was ran on low oil.
What I need to know is, do I have to remove the timing chain to remove the camshaft? I'm really dreading trying to do it with the motor in the car. Or is there a way to remove the sprockets and then lift the cam out?
Heres two videos showing the issue. Please let me know guys, we're trying to get this car going as soon as possible.
TransAmBand1t is offline   Reply With Quote
Old Nov 02, 09, 05:36 PM   #2
Mean Green G20
G20 Guru
Mean Green G20's Avatar
Feedback: (9) (100%)
Vehicle: '95 DJ2HP10
That is freakin' crazy! I have never seen a cam do that before. Search on here for threads about changing the timing chain. They will show very clearly what needs to be done to get that cam out.Also, become a member and download the FSM. It will tell you exactly how to do the job. Something tells me that there is more going on than just a broken cam though. For one to do that something must have siezed up. FYI, The cam sprocket is bolted on to the end of the cam you can just remove the bolt and take off the cam gear and then replace the cam. Good luck. It is a tough job if you have no experience wrenching. Just wanted to give you a heads up on that.
__________________
Greetz,
Ben
Mean Green G20 is offline   Reply With Quote
Old Nov 02, 09, 06:31 PM   #3
thunder storm
G20 Guru
thunder storm's Avatar
Vehicle: 1999 G20 M/T!!
make sure you get it put on the right tooth. from my experiance, with the stock cam if it's off by one tooth, you won't bend anything, but it won't go higher than idle. had to deal with that pita when i switched to a highport cam.
also if at all possible do not unbolt the chain tensioner, because the oil filter will be in the way, unless the hiport has it lower on the back of the motor, then you shouldn't have anything in the way.
__________________
thunder storm startled the witch!
---end of line---
thunder storm is offline   Reply With Quote
Old Nov 02, 09, 06:49 PM   #4
Robj80
AKA robkris8079
Robj80's Avatar
Feedback: (12) (100%)
Vehicle: p10 & C11 yes C
motorswap it. I know the car your talking about. I was considering buying it but never thought of trying to fix the engine that was in there due to the way the guy listed it. I think you will be better off with a de swap.
Robj80 is offline   Reply With Quote
Old Nov 02, 09, 07:21 PM   #5
P10 Goodness
G20 Junior Member
P10 Goodness's Avatar
Feedback: (2) (100%)
Vehicle: 1996 G20
might as well just try putting another cam and sprocket in? Heck, we got two intake cam spares in the garage... they are low ports, but should work ok on a high port.
P10 Goodness is offline   Reply With Quote
Old Nov 02, 09, 07:31 PM   #6
Mean Green G20
G20 Guru
Quote:
The highport cams have bigger lobes and give a bit more HP. The lowports will work but I would only use one as a tester and search for a highport cam to put back in there. The car will run much better if you do.
__________________
Greetz,
Ben
Old Nov 02, 09, 07:49 PM   #7
markbuts3
G20.net Staff
Super Moderator
markbuts3's Avatar
Vehicle: '94 Primera eGT
Looks like the valves on cyl 3 are open, for those valves to be open and the engine to still crank over means something has got to be bent.
Hard to see in the vid properly though.
__________________
Just call me Mark
My Site
markbuts3 is offline   Reply With Quote
Old Nov 02, 09, 09:35 PM   #8
thunder storm
G20 Guru
nnooooo, we can't sell the anti-zombie weapons.... lol
__________________
---end of line---
Old Nov 02, 09, 09:41 PM   #9
Mean Green G20
G20 Guru
Quote:
I now have a new use for my old cams. Sweet.
__________________
Greetz,
Ben
Old Nov 02, 09, 11:33 PM   #10
TransAmBand1t
G20 Newbie
Feedback: (0) (0%)
Quote:
Thank you for your response. Not new to wrenching, been doing it a few years and in HIgh School. I have a PDF for a 95 FSM and access to ShopKey. Right now we're looking for a replacement cam. From the looks of it I might be able to seperate the sprocket and remove the cam. But the cam its self might be shot too.
I will try my best to time this thing correctly. Trying to avoid taking the whole timing chain off.
Quote:
He listed it as all it needed to run was an oil pan, and even when we went to look at it, he insisted all it needed was an oil pan and that the timing chain still had life to it. No where did he mention that the motor was fucked.
Old Nov 03, 09, 01:22 AM   #11
bender-san
G20 Member
bender-san's Avatar
Feedback: (0) (0%)
Vehicle: 1995 G20t
Something will almost certainly be out of sorts in the valvetrain besides the camshaft being broken. It doesn't take much to bend a valve on a Nissan chain engine.
bender-san is offline   Reply With Quote
Old Nov 03, 09, 07:45 AM   #12
Robj80
AKA robkris8079
Robj80's Avatar
Sorry you are right. I think it's just I've been around SR's for quite awhile 99% of the time if someone needs a new oil pan and the car doesn't start it needs a new engine. I have seen a tiny dent start a motor of oil and blow it up.
__________________
WTB p11 automatic in need of mechanical love, let me know what you got
Old Nov 03, 09, 11:50 AM   #13
TransAmBand1t
G20 Newbie
Feedback: (0) (0%)
Sarcasm? I really cant tell.
Old Nov 03, 09, 12:00 PM   #14
Robj80
AKA robkris8079
Robj80's Avatar
Quote:
No I wasn't being sarcastic. Reading the add made me say in my head "it needs a new engine". This is just going by experience here. If I offended or came off sarcastic I apologize. I was saying you were right because most people would see it and just assume just an oil pan was needed. The seller of the vehicle should have never put all it needed was an oil pan. SR's are very touchy when it comes to the oil pan. A small dent in the right spot can block the pickup. Or even not in the right spot but low oil and a hard corner can be the death of the engine as well.
__________________
Old Nov 03, 09, 12:07 PM   #15
TransAmBand1t
G20 Newbie
Feedback: (0) (0%)
No need to appologize dude, it was probably just how I read it. Thanks for the info though. The seller was out to dick the person buying the car. That's all. I dont know if the oil pan was really shot or not as it wasnt on the car. He did offer it to us, so maybe it was. But from the looks of the cam lobes, it might have been ran on low oil.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2007 G20.net
Smilies are copyright © 2002 Dark Project Studios
