I made 162 hp at 6170 rpm and 144 lbf-ft torque at 5180 rpm!
The only thing I have done snice the last rolling road run was to add the HSH (including the HSH downpipe). At the last RR i only made 145 hp and 136 lb-ft torque!
Fastest N.A P11 in the UK? :alien: :D :confused: :)
I'm assuming these numbers are at the crank/flywheel? That's a REALLY nice gain from just one mod :) It's weird though, you're hp peaks a little lower than normal, yet your torque peak is higher up in the rpm band than normal. Where did you car peak at last time?
128 hp
GT intake CAM, GT mid section, powerflow back box, k and panel filter, hot shot header and downpipe
Should be getting new crank and water pulleys soon.
Both dyno runs were at the same Rolling Road.
Discussion Starter · #8 ·
Still got the CAT and the standard GT mid section!!! Whe I add a unichip, pulleys, mid section, de-cat and induction kit ill be looking for 175 hp:smoke: .
my old P10 put out over 200 bhp (no turbo) but i had i lot of cosworth one of parts on it, and the engine was blue printed by a cosworth engineer who was a friend of my old mans.But he died before the engine was completly finished (he and my dad used to be rally drivers together in the 60's).Which was a shame cos who was gunna do a turbo for me (400-500 bhp) cos he thought the sr20de had a tremendous amount of potential.(i have spoke about this in a previous thread.
