1991 Nissan Primera GSi P10
Hi all,
I recently purchased my first Nissan Primera after wanting one for many years. Being from the UK I thought it would never happen as most of them have rotten away. I picked this up from a welshman (completely sight unseen) who had previously owned 2 eGTs and actually owned his own dealership. This car was his and he owned it for 14 years, although for the last 12 it hadn't been used. The car has been garaged for most of its life but there are some rusty bits, as I will show below.
The car being delivered!
20153
20154
20155
20156
Some interesting things I noticed immediately. The lack of radiator left haha! Also an asbestos firewall?
20157
20158
Original tape deck?
20160
Engine looks good, maybe a rocker cover gasket leak but other than that seems okay. Its a single port SR20 and has covered 140k miles.
20159
My plans for this car include a 5 lug hub conversion, some R32/33 GTR front seats, R32 GTR wheels, coilovers, half cage, full interior. Nice an OEM+. Potentially and engine swap in the future to a more modern unit.
More to follow...
Fletch
Discussion Starter · #2 ·
After have a quick look around I decided to give it a quick clean and get it into the garage and up in the air, at this point I wasn't sure whether it had the rear independent suspension. I was happy to find that it does and apart from a small coating of dust/mud the components and rear sub frame all look in great condition. The previous owner completely undersealed the car at some point which I think has helped. The rear arches and sills have been repaired in the past.
20163
20164
20165
20166
20167
20168
20169
Fronts are bit cob webby, but over all very solid.
20172
20170
20171
Cheers,
Fletch
Decided to try and track down some of the orange stuff, I know there will be some somewhere. Living in the UK these cars ALWAYS have rust on them, they just do. This is showing signs on the exterior so there I knew there would definitely be some lurking within. I started by removing the rear seats and peeled back the carpet. Alot of you will know they are renowned for going bad in this area.
20173
Nice self tapper left behind by the previous repairer. It looked abit crunchy here so was worried that it may need re-doing, however despite its looks, it passed the screw driver test and seems solid. I will be spending some time make this abit more presentable in the future.
20174
20175
Bit of surface rust, but again all solid suprisingly.
20176
After a quick clean up with the wire brush, I will be protecting these areas (infact probably the whole rear seating are and floor).
20177
Now, into the boot (trunk)....
20178
After the screwdriver test....
20179
This is the right hand side of the vehicle (always worse in the UK) as we drive on the left, so when parked up in the street, this is the side that is next to the moving traffic. Gets all the splash back and road debris soaked into it. After I found this I was pleasantly surprised, it could have been ALOT worse and this should be relatively easy to contain and repair.
Pictures of the left hand side rear arch and floor highlight this difference.
20180
20181
Boot floor looks okay as well. Bit of surface but thats all! Happy days!
20182
Cheers
Fletch
Further exploration into the boot area I discovered the original jack and tools!
20183
And underneath....
20184
20185
20186
Very orange! This area seems to have been full of water at some point and for some considerable time by the looks of it :(. After this I decided to get abit stabby and it went straight through, so that area will all need to be cut out and replaced. Looking deeper into that rear arch area I discovered another patch on the inner arch so this will need repairing. I poked this through to the outside aswell.
20188
20189
Unfortunately, removing the rear bumper exposed the worst of the rust. Prepare your eyes.
20190
20191
20192
More to follow...
This was the aftermath of all my poking around in the right hand side chassis leg...
20193
And just a comparison, the left hand side of the car, once again, is in much much better shape.
20194
20195
20196
20197
Overall it isn't great, but compared to others i've seen and even some P11s I've seen it could have been way worse. I'm quite happy that the work required will only effect one side. Now time to get saving up ready to get it sorted. I'll keep this thread updated with any work I do or bits I buy for this :)
Cheers guys,
Fletch
