Sure you can. You can swap pretty much anything else you want, but i wouldn't really see the point... Use the flywheel/flexplate bolts that came with the unit (IE: automatic flex plate bolts are shorter, dont use them with the manual flywheel and vice versa.) You will need to make sure that the pilot bushing on M/T engine matches the pilot bearing on the A/T engine and possibly replace it if needed, but i think they are both just a type of alloy bushing and it's possibly the same one...
