1 - 8 of 8 Posts
1995 infiniti g20 auto
So I was driving home earlier today in my 95 G20, everything seemed fine until the battery light and parking brake light came on all at once. I noticed the car got stuck I'm third gear and acceleration was a little sluggish and wanted to die. I turned the car off when I made it home and It won't crank now. I tested the battery at 13 volts with the key off. Can someone point me in the right direction please?
Discussion Starter · #2 ·
Today I started tinkering on the G20. It's an auto so I tried to start it in neutral and the car didn't crank. I jumped the starter solenoid and it sputtered. I hooked a noid light up to one of my injectors and no light come on. I checked all my fuses and relays with ones I knew worked. So I went ahead and pulled the ecm on it and ordered a new one. Does anybody think it's the ecm?
Always never the case
Anti-Theft?
Do you hear the click noise from the starter?
Cheers
No clicking noises from the starter unless your directly jumping it on the solenoid. I've tried unplugging my anti theft to reset it, I've tried locking and unlocking the doors and I've tried the relays with ones I know are good
So Ive tried checking codes with a reader and nothing pulls up. I tried checking codes on the ecm and it gave me code 8-4, crank position sensor. Would this keep my car from cranking or firing?
So I read the code chart wrong and looked at the one above it. Has anyone messed with code 0804 (a/t diagnosis communication line) where they can't start their car? No crank at all? I checked the search bar already but most testing procedures need the car running?
1 - 8 of 8 Posts
