1999 Infiniti g20 reverse lamps not working
4973 Views 5 Replies 3 Participants Last post by  WeazG20
Ok so both my reversel lamps are not working. bulbs are good. As far as I can tell whatever it is is just effecting the to reverse bulbs on the diagram that i have. it states that there is a reverse lamp switch. does anybody know where the heck this thing is? thanks. Also i am looking under the dash and do not seem to see any associated fuses. are there any?
thanks
Switch is on the tranny... blue plug. Have you disconnected the trunk harness and ohm'd it out yet? After 12-13 years of bending over a hinge sometimes a wire just breaks.. I personally would start there since its free ;)
I agree most of the time it is that harness
yep!!! harness was severed at the hinge. However, I repaired all the wires and the revers lights are still not working
OK after peeling the brittle hardened rubber tubing off I found a total of 10 broken wires LOL i used some corrugated wire tubing and alot of wire crimps with the built in heatshrink. The whole trunk lights up again as it should and the reverse lights work..sheesh
