When closing sunroof it doesn't stop at closed position but continues on to tilt open position. I have to play with switch to stop it when I think it is in closed position and this requires extremely good reflexes is get it right. Anyone have any idea which part needs replacing? Open/close switch? Thanks for your suggestions.
Well im not sure what Piece is broken.. BUT I do have a 1999 p11 that is ready to be parted out and luckily I have a perfect Sunroof.. LMK if you need some parts GL
Also Im not so sure if there is anything broken... Mine does the same thing when trying to close it you kinda need to let go a little early before it closes all the way otherwise it goes to the tilted position like I said though let me know
My '99 G20 tilts up an down without a problem.
It's when I try to slide the roof back (towards the trunk) is when it stops halfway. It doesn't go beyond the halfway position which is a bummer because I like my roof wide open. I have to inspect it and see if the track is broken or something is obstructing it from opening all the way.
