Does anyone know where the thermostat is on a 1996 200sx with the 1.6L engine? I am trying to help a friend out and I am afraid I bit off more than I can chew.
I think if you follow the radiator hose from the bottom of the radiator and trace it to the engine, take out that radiator end that connects to the engine; that is where the theromstat should be. I think.
you guys are all wrong. I pulled the upper radiaor hose off and the housing only to find nothing there. It is above the water pump. How fucked up is that. I need to rent a midget for tomorrow because the work space looks small.
Yeah, on the 1.6L motor it's back behind the water pump... there's the thermostat housing off the side of the pump, then the thermostat itself sits right on the backside of that... you'll see the small triangular thermostat cover w/ the 3 bolts, simlar to the SR one, and it's right there.
