is this too wide? there are 195/60's on right now, there is a good deal on some toyo proxes h4's with 5000 miles on them on craigslist.
205/60's range of ideal wheel widths is 5.5"-7"
They'll be taller though so will probably cause fitment problems in the rear of a P10 and require spacers. Iirc, the stock wheels are 45mm offset....
205/60/14 - 23.7" diameter (38-42mm offset required)
It also matters about the brand of tire too for it to fit without spacers or you most likely have to put on spacers with most brands @ the rear. I had a problem with this on my NX, but that was with 17's. Just my .02 cents.
