1 - 2 of 2 Posts
My stock LSD 5 speed shifts fine if I'm just cruising around, but wont go into gear at high rpm's. its got a new slave and a stage 2 clutch with a 12lb flywheel. it's got 300k on it so I'm thinking it might be the syncros are worn. Any help on this is appreciated.
Could it be the end result of the 5th gear pop out problem that is somewhat common in the SR20DE manual transmission? I think I recall hearing that once the 5th gear pop-out has been happening for some time, it can eventually get so bad that the clutch can no longer hold it gear when shifting from 4th to 5th gear.
1 - 2 of 2 Posts
