1 - 20 of 40 Posts
Discussion Starter · #2 ·
also has some audiobahn rear spks with tweeter splitter/controler. I also have heavy pwr wire for rear pwr amp (car came without amp)with scosche fuses. Exterior lights are gone. antenna mtr runs, but needs new mast.
If the crossmember mount is different than the cross member itself ill take the crossmember. also clutch cable mounting plate and flywheel.
yes they are good. Everybody be paitent. My arm is in a sling from surgery on my shoulder yesterday. I am also new to this. I have no feedback yet. I am straight up and will not screw over anyone! you can also pm me.
Discussion Starter · #7 ·
re
junknstuff said:
is it a 5spd and can i get the front crossmember motor mount please?
also, do you have any feedback? that would probably help your sale as well
Is what you call the crossmember the same as what the book calls the center member?
Do you have the power steering line that runs up to the strut tower and down to the pump? Banjo bolt on both ends. Is it in good condition?
Discussion Starter · #16 ·
emer cables
visioneer_one said:
Excellent. I'll take them.
I can also use the left & right e-brake cables. One of mine was cut by a brain-dead mechanic, the other one is frozen in place (corrosion)
Let me know if you've got those as well.
I do have them. PM me.
Discussion Starter · #19 ·
xmember
I can get the crossmember and the clutch cable mounting plate but not the flywheel. If still intrested pm me.
scott
1 - 20 of 40 Posts
