hi I got a 91 g20 and i want to know if i take off the abs wood the still brake the same.or what wood happen if i did.thanks.
If the ABS system is disabled or doesn't work (ABS computer gets a fault when it tests the system each time you drive it), then it goes into default mode and just works like regular brakes. So, if you take off the ABS, it will work OK, just no ABS.
Just pull the fuse, you will then have a non-ABS system with alot more fluid capacity than the regular non-ABS system... which is a good thing because it takes longer for the fluid to heat up.
Why would you want to do this?
Are you having a problem with the ABS?
