I have up for sale a 1991 Nissan Sentra SE-R 5 speed (white). It has been a project car for about a year. I have done an extreme amount of performance/suspention modifications. This car is capable of 450-500 whp easy. I have a list of mods below. This car was bought in driving in Arizona until 2004 when it was driving up here. I have purchased this car off an older man that did not beat on it at all. The body is a 9 out of a 10 for the age. The paint is awesome and absolutely no rust at all or any indication of any started. The odometer reads 187,XXX but that was replaced due to broken Speedo last year by previous owner (cluster). I am the 2nd owner of the vehicle as I was told. This car has upwards of 17k invested and having to sell due to my second kid on the way. If you have any question's at all e-mail me and ask. Here is the list of mods.
1) u13 sr20det engine tranny combo $1700
2) Protech Manifold & Dp (3 inch) $1310.96
3) T3/TO4E 60 trim 57lb per min (550 whp capable) $910
4) 1994 z32 MAF (300zx TT) $170 used
5) JWT ECU Tuned for car mod's $550
6) Deatschwerks 740cc injectors $410
7) MSD 6AL Ignition $380
8) MSD Timing Control 15* (retard or advance) $155
9) MSD Coil $40
10) Tiel 44mm wastage Internal Dump $340
11) Innovative LM-1 Wideband O2 sensor $400
12) Stock SRT-4 FMIC. Good for (500 whp) $150
13) Greddy Grounding straps $20
14) Koyo Radiator 55mm thick $335
15) Flex-a-lite 10 inch duel fans. (Ignition Turn on) $220
16) Blue Bird B.O.V $40
17) RSL 18's Black with silver lip. $880
18) 215-35-18 Parada Spec 2's $825
19) JWT S4 Cams $550
20) B&G Lowering Springs $220
21) Gr2 Struts $160
22) JGY Clutch (Stage 4 as they would call it) Rated at 500lbs TQ $399
23) JGY Flywheel 8.5 pounds $269
24) All Autometer oil,boost and a/f gauge's $160
25) Polyurethane motor mounts (Almost Solid) $150
26) Stock rims in mint condition with brand new 195/60/14's Kumho KH 18 Tire's $280 Maybe 50 miles on them.
27) APR Head Studs $110
28) Cometic Head gasket MLS $100
I'm sure I'm forgetting a lot but that's most I can remember off the top of my head. The interior of the car is a 10 out of a 10, everything looks brand new inside. Also a non smoker car. This car is not gutted at all. Every piece still intached but the spare? No clue where it is. This car has not been driving in the snow by me at all. I think the last owner did for one year. Also No big dents or scratch's. Contact me at [email protected]. Thanks For looking. Just so you no....The car is capable of high 10 sec passes with a cage and drag slicks. I am hoping to get Around $9000.00 or BRO!
http://www.cardomain.com/ride/2532606 PICS!!!!!!!!!!! I might trade for a 4 door somthing..... g20,spec-v....
Sorry to be off topic, but is that the fwd bluebird gearbox (marked 79E) in ther se-r? If so I have a couple of questions:
-what did you use for your clutch master cylinder/slave master cylinder combo (assuming u kept hydraulic set-up)?
-what did u use for the driver side mount on the gearbox?
btw, very nice set-up, I'm sure someone will be interested.
EDIT:
*Nevermind based off the picture I just saw of your set up, it looks like u used an se-r box*
Yup all just bolts right up. Thanks for looking. Its the stocker cable setup. (old school)haha
Any offers? Low ball me Just so I can say no! Thanks
I would consider $6,000 if it was in my face right now..........Stressing bad over another kid!!!
