I looked in the search and faq to no avail. I cant figure out where the timing teeth are on the crank on my 93.5 P10. there is no where to tell what degrees the motor is timed at... or is there some special groove on the crank? how does one go about this on a 93.5 P10?
if you get the timing light on there you should see it... It's on the pulley and the motor has a little stick mounted on it to show what the timing is set at.... here this should help you a bit....
how to advance timing
