1 - 12 of 12 Posts
Does anyone know if a 93 Instrument cluster will work in a 91?
CH0DEmobile
Is it a 93.5 or 93 cluster? IIRC, they switched from cable to electronic speedometers in 93.5, so you'd have to swap in your 92's speedo if it's a 93.5 cluster.
Yeah, basically you need to establish if its a 93 or a 93.5 that the cluster came from.
93 = automatic sliding seatbelts, black door handles and rocker panels
93.5 = new grill, MANUAL seatbelts (like the sentras)
If you don't know or never saw the car that it came from post a picture of the gauge cluster and I will be able to tell you by that.
93.5 cluster won't work for you unless you want to "modify" it there is a spot on the back that you can drill out so that it will accept the speedo cable.
Chris
CH0DEmobile
Don't the 91-93 clusters have white symbol outlines on the warning lamps? I know my 92 does, but on my 95, you can only see what the lamp is when it's illuminated.
Yeah your right, and they changed the "font" of the letters a bit too.
Heres the 93.5-96 gauge face for the speedometer:
Chris
Discussion Starter · #7 ·
here is what the cluster looks like...
I wish I could see what the back looks like...
p10 guru
^^ that looks like the later (93.5+) cluster
Discussion Starter · #9 ·
cool thanks...
back to the drawing board I guess...
Not really, I told you.
You can drill out a spot on the back of it to make it accept a speedometer cable.
Post a picture of the backside of the cluster please.
Chris
Well regardless there is a way to modify that cluster to accept your speedometer cable so you know.
Chris
1 - 12 of 12 Posts
