Ok so these seats are powered and mine werent, if I get the clips that clip to the bottome of the seats, is t hard to wire them so I ca actually adjust these things?
Hell no... Just find a power source, and hard wire it.
Just decide if you want them to adjust when the car's not on. You'll need a constant on power as opposed to switched which will require you to be in the "on" or "acc" position with the ignition.
not hard at all..get 12gauge wire run it from the positive battery terminal with an inline fuse and holder (i used a 40) run it to the positive wire on the chair and ground it not so close to the chair..
Thanx alot guys...Really appreciate it :thumbsup:
