Car wouldn't start, discovered it was a loose battery cable... tightened it and now my fan blower is on high and will not shut off. Digital display that shows fan speed is flickering also. It does shut off when ignition is off... any suggestions?? Thanks!
Kristy
just unplug the battery again and wait a few seconds. Then reconnect it and you should be all set. Same thing happened to me when I put in a new battery. Might even be able to just remove the fuse and reinsert but I did the battery cable.
