I just manually reset my ECU and read the flashes on the service engine soon light, it flashed 6 long, 8 short, pause then 1 long, 2 short, I think this means cylinder 1 misfire and a bad Maf sensor, thing is i got a diagonstic done at a nissan dealer, they had the cylinder one misfire too, but not the MAF. I think I may have triggered the MAF code because I unplugged the sensor to inspect the connection after the diagonstic. but if the MAF sensor is still good shouldnt there be no code coming up, since I did reset the ECU, or are all codes perminantly storred in a memory, also could a bad MAF give you a missfire on cylinder one, or are they totally unrelated, if I do have a BAd MAF why diddnt the dealer pick it up. or is it just a code that I triggered when I unplugged it and now wont go away?
Discussion Starter #2
how do you completly erase all codes from the OBD 11, so I can see if they come up again and are legit, do I unplug the ECU Harness?
bring it 2 a auto zone they will reset it for free with a computer rather then that the same way you did it last time by hand
I've had my Check engine light and reset it by hand but it turned back on the later the same day. I counted the flashes. Flashed 5 long, paused, and 5 short and it kept repeating. anybody know what seems to be the problem?
p11driver, your code:
68 - Misfire detected - cylinder no. 1: Check number 1 spark plug, ignition wire, compression or injector.
12 - Mass airflow sensor/circuit: Mass airflow sensor source or ground circuit(s) may be shorted or open. Check the mass airflow sensor or circuit.
818_'99G20, your code is:
55 - Normal engine management system operation is indicated
