Ok, I'm in the process of installing my intake right this second. But, I have a pretty big problem. The Air Temp sensor will not reach the top of the air filter! They said I need 3 to 6 inches of slack, but how in the f**k do I get that much slack in wiring that's in the car? I don't know how to get the air temp sensor to the top of the air filter. Please if anyone can help!
Hmmm.
Well I had the same prob on mine, but I just left it in the old stock cold air intake pipe. I didn't hook it back up to the actual stillen POP.
:paranoid:
Anyone else? I just couldn't find anywhere to put it, so I left it alone, am I the only one? Is it that importaint?:paranoid: :paranoid: :paranoid:
G-Forces said:
You mean something like this?
I just extended the wire, cut the old wire and extend it, then solder it.
After pondering for a while I figured it out. I just cut the electrical tape around the wiring loom to the right. And extended the wiring. It sounds GREAT! I love it.
Thanks for the help anyways!
I did not know if the 99's were simiiar to the '96's or I woulda posted a while ago. Sorry. All I did was the same thing. I cut some of the elctrical wrap away from the wires and it gave me the exact length I needed to put the sensor on the end of the filter w/o cutting any wires.
See here:
http://nismopc.tripod.com/filter.htm
