1 - 2 of 2 Posts
Internet Mechanic
I took the stock 2001 touring wheels and tires off my p11 (*195/60/15 - 24.2" diameter (35-45mm offset required)*(99-01 Touring)
and now want to put them on my p10,(which used to have *195/65/14 - 24" diameter (35-45mm offset required)*(93.5-96 P10)
but when i installed the drivers side rear the cup holding the bottom of the spring was rubbing against the top/inside of my tire. it even left a small rubbing mark on the tire
what can i do to make these work? Spacers in the rear? Is there possibly a problem with my suspension? Is it the difference in the overall diameter of the p11 wheels which is casuing it to rub?
P10 FTMFW!!!
Go with a 5mm spacer and you should be ok...how much of it was rubbing? Just a small bit? If you really wanted to you can put a 5mm spacer up front as well to make it look the same
1 - 2 of 2 Posts
