any electrical issues to be known about, engine problems? like consistent stuff, or is the sr20de a pretty god damn reliable car and all i have to worry about are the seals and bushings and standard stuff like axles, ball joints, seals, timing?
Those are all dependent of mileage, if you got a high mileage car you'll probably need to replace more suspension components. The starters are known to go bad, I've replaced 2 in my years. That is also on 2 different cars though. Also, the climate control lights tend to go out. Also, the tach may go crazy on ya. Other than that I've had a happy relationship with g20's.
structurally speaking, are there any weak points, like a weak subframe that is common for rust or rear bad rear quarter panels that always rust out? stuff like that
I have surface rust on my sideskirt, nothing major. These cars don't develop honda rot if that's what you are thinking of. And yes, you can get parts from any car with the sr20de. If you do a search you will find there are differen't variants of the sr20, highport, lowport, etc.
The front fenders may well rust out -- stuff gets down underneath between them and the frame and rusts through the fenders. I also have some surface rust on the frame because of it (right below the fender), but nothing catastrophic.
Even with the different SR20 variants, a lot of accessories transfer over. Headers, clutches, and alternators work on all SR20s, and cams as well as some other parts work on all pre-2000 SR20s. The main difference within the 1990s was that they switched intake designs midway through.
