1 - 2 of 2 Posts
I have my advanced timing set at 19degrees. I'm getting my UR pulleys installed this week. Would I have to adjust the timing? Yahnozha told me I wouldn't have to, but I'm just double-checking to make sure. Thanks.
He's correct, you shouldn't have to. Maybe double check it see where the lines line up at (make sure they are in the same spots as stock, if not make a note of the changes). The distributor changes the base timing, not the pulleys, so you'll be fine.
1 - 2 of 2 Posts
