Hey whats up, im not sure how many of you guys know this but AEM now makes an intake for 91-94 SE-R's, 91-92 being for the High Port SR20 and 93-94 being for the Low Port. This intake has been found to make over 10hp on an SE-R to the crank I believe I dont think it could be that much to the wheels but I was wondering if any of you guys know someone who has made the kit for the 93-94 SE-R fit a 94-96 P10, if so please let me know because I know a guy that can get this kit for a reasonable price, I have talked to AEM about this and he said the only problem youll have is having to drill a hole in the pipe for the air temp sensor but otherwise it should fit fine. Thanks.
Don't know if it helps but fitting a 96+ AEM on a P11 was too much of a hack job to be worth it.
Im not really sure how it would be on a 99+ G20 but im talking about a 94-96 G20 which is more similar to a 93-94 SE-R low port SR20 I think then a 99+ low port G20 SR20 cause there were more changes done to the 99+ G20 SR20 then there was 94-96 G20's, the fitment should fit just like it would on the SE-R the only problem the guy at AEM told me id have is with the air temp sensor that goes in the stock intake box which the 93-94 SE-R's dont have.
I don't know about the AEM intake but I know that if all you have to do is put the air-temp sensor in line somewhere that would be a snap. All you would have to do is drill three small holes in the intake pipe somwhere. (one for the sensor and two for the screws to hold it on.
Are you talking intake or CCOLD air intake. Intake should be no problem CAI could be.
No I don't think you are understanding what I'm saying. The 96+ SE-R has practically the same motor as the 99 G20. I tried to fit the AEM from a B14 (96-98) SE-R into a P11 and the CAI piping would have had to been hacked apart to make it work. I don't think the P10 and B13 engine bays are all that similar to each other. Get it and try it.
I KNOW that the B14 AEM CAI won't fit the P11 with out cutting it up. I'm guessing the B13 won't fit the P10 either. Better off just getting a PR or Hotshot CAI.
