I searched and searched for a definative answer with no luck on how to turn off the airbag light after removing the OEM seats. I have no electrical knowledge whatsoever and became confused. So hopefully someone else will find this info helpful.
What resistor do I use?
Where the hell do I put them?
You just need two 2.2ohm resistors(not 2.2K) and they can be plugged right into the yellow chassis harnesses under your seat that protrudes from underneath the carpet.
I wrapped them up with electrical tape afterward too so that it would look pretty.
You might need to do the airbag reset deal where you hold the key in the ON position and press the door button 7 times.
Here's some photos to further assist in your endeavor.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
