It will work if you FIX the problem and have to reset the light. Your light is flashing because your AIRBAG MODULE is bad. Replacing it is the only way to make it go off
Nothing. The owner's friend doesn't know what he is talking about. You need to have the diagnosis from an Infiniti or Nissan dealer before you buy the car. Do not make an expensive mistake. This is a critical safety system. If they will not allow you to get the car looked at, then run, not walk, away from this car. Air bag light could be on because of failed air bag module, failed sensor, or missing air bag.I'm about to buy a 99 G20 with the airbag light as well.
The owner's friend said that the car's airbag light is on because they had the driver seat replaced...
What would that have to do with anything?
Thanks for the advice, I'll try to take it into a shop or something tomorrow.Nothing. The owner's friend doesn't know what he is talking about. You need to have the diagnosis from an Infiniti or Nissan dealer before you buy the car. Do not make an expensive mistake. This is a critical safety system. If they will not allow you to get the car looked at, then run, not walk, away from this car. Air bag light could be on because of failed air bag module, failed sensor, or missing air bag.
The airbag light was flashing.The SRS light only flashes when the module itself is bad. If it was a failed sensor it would just stay on solid
Yeah but your brother had a collision shop. They're professionals there, its what they do.i have changed airbags and modules on many cars before the main thing is to have your ignition on off and for added safty take the cables off your battery. My brother had a collision shop and they changed the airbags all the time and i do not recal a single time when anything went wrong. if the airbags have been deployed before and you hook up new airbags to it a light will go on it wont just automatically deploy them again. but it is best to check your sensors first and then your module
