1 - 7 of 7 Posts
I'm selling all of my SR20 / G20 stuff. All good condition parts and I'll get pics of whatever you need just let me know and I'll text them. Also let me know your name / address if interested and I'll get a shipping quote for you. Please PM me with all questions.
SR20VET head with P11 VE cams, VE rockers, cam solenoid and VET valve cover - Bolt on for DET or 8.5 CR pistons $1000
SR20VET rods - $125
SR20VET pistons - $150
SR20VET crankshaft - $150
SR20VET oil pump with pickup - $75
SR20VET RE4F04B 4 speed automatic with FWD converted CV axles, Axle bracket, Transgo shift kit, rebuilt new clutches, Phantom grip LSD - $900
SR20VET RE4F04B AWD stock transmission - $300
SR20VET T28 turbo manifold - $75
SR20VET intake with fuel rail - $150
SR20 20V Head with SR20 20V cams, cam solenoid and valve cover $1000
SR20 20V crankshaft - $150
Sr20 20V rods with pistons - $100
SR20 20V oil pump with pickup - $75
SR20 20V Intake with fuel rail - $150
SR20 20V Exhaust long tube exhaust manifold - $100
P12 6 speed manual transmission with Maxima 3.81 gearset and 20V SR20 Bellhouse - $700
Garrett GTX3071R turbo kit - Sch40 steel tubular manifold, Tial .64 stainless housing, Tial MVS 38mm wastegate, 3" stainless downpipe, 3" stainless J pipe - $1450
Bare SCH40 steel GTIR Tubular T28 Turbo manifold - $150
Brand new in box SR20 N1 cams - $450
1600cc Black Ops 4x injectors - $350
P11 5 bolt conversion - rear spacers, ABS rings and 5x114.3 hubs, front spindles and drilled 5x114.3 hubs - $200
Qx4 twin piston calipers - $75
Spec-V Brembo 4 pot calipers - $300
P11 JDM Glass headlights with corners - $225
Ogura ORC-659D twin disc S15 clutch about 4000 miles - $800 (was $1500 new)
Exedy NH02SD1 Hyper Aluminum Super Single S15 clutch needs resurface and disc - was starting to slip under 20psi - $250
GM LS coils with heatsinks and mounting plate for VET valve cover - $80
Spec V black leather steering wheel with air bag - Direct swap with P11 - $100
HAhaha... no way. I picked up a couple G35x's (V35 and a V36). Just moving on to bigger heavier things.
Headlights = Sold!
1 - 7 of 7 Posts
