1 - 20 of 28 Posts
Used to own a P10
130 MPH speedometer. You can get up basically that high on level ground.
Used to own a P10
You guys also get an oil pressure gauge. :(
Are those chrome rings stock? They look great.
drunken master
I have buryed my speedo in 4th gear and peged the needle out. never went for a go to end of 5th gets to scary
markbuts3 said:
130mph speedo ?? That's pathetic :p
Try 150mph speedo ;) Stock top speed for a P10 eGT is listed as 137mph.
would that speedo work with the USDM P10 G20's? It looks sssssoooooooo good :cool:
It might work with a high port. All UK P10s are cable driven, whereas the G20 switched to an electronic speedo....You'd also need a dual sender from an eGT for the oil light and gauge.
My old set of gauges went into an early 1.6 carb P10 and plugged straight in apart from the need to run a wire for the oil gauge.
Nissan dropped the oil gauge late in the P10 production, and also switched to red needles.
its a 3k lb car with 140 horse...130 isnt bad...
KwikyMAN said:
mine topped at 135. it was kinda scary...especially when i was coming up on deer guts in the middle of the road...
yea and you have a highport engine with higher redline and probably higher rev limiter
Used to own a P10
Point being? The car can't get to redline in fifth gear...
1 - 20 of 28 Posts
