i just changed out the thermostat but as i was driving to work this morning, the car started overheating again. it seems worse now because when i turned on the heater before, it would cool the engine down but that didnt help. do you suppose that the water pump is bad?
please, help me.
thanks
i'm pretty sure that i put it in the right way. are you talking about upside down or inside out? either way, i put it in the same way that i took it out.
the fan does run but i dont understand why it would cool the engine off before but not now.
As mentioned by others, make sure you installed the thermostat correctly. Make sure the radiator fan turns on when the engine gets hot. Also, did you bleed the air out of the system? There is a procedure to this in the manual. I am at work now, so I can't look that up for you. Maybe someone has access to a manual right now and can advise.
John
