1 - 7 of 7 Posts
Pizdeet kak Trotsky
As you can see its nothing major, its just that it has occured on a sleeved bit of the suspension turret kinda area ...... What should I do about it ..........? Pay some dick £200 to chop it out & weld in a new piece..... Or get busy with some products ?
:beard:
no way bro, its just surface rust. to be sure, check under the wheel to make sure the rust isnt starting from the inside out (prob have to pull that plastic back) i would hit it up with a grinder and slop some rust inhibitor on it(available at any hardware store), take a can of universal black paint, tape off and cover spots for overspray, and spray away.
Used to own a P10
If it's rust-through it'll be easier to tell than that -- you'll be able to jab your finger through with medium pressure. Furthermore, in my experience rust-through only looks similar to that when it starts from the other side, and there's nothing in the strut tower that would hold enough salt/moisture/whatever to start that large an area of rust-through.
actually mine doesn't look quite like that, I just have the seam sealer pealing, no real rust
Pizdeet kak Trotsky
Its not bad rust ......... Tried the good old fashioned Screwdriver with a hammer behind it test........No prob ........ I'll just have a we chop at it with Mr Grinder & bodge it up with a few after markets then :D
1 - 7 of 7 Posts
