1 - 20 of 31 Posts
P10 FTMFW!!!
So I think my auto tranny is either going or pretty much dead. Won't shift into first or reverse, makes a crazy whining sound in neutral, fluid is now brownish (i looked 2 weeks ago or so and it was red). Basically it sucks right now.
So i'm gonna try and get all the 5-speed swap parts together a bit sooner than i thought (like ASAP).
I have a list of parts bought or pending sales...can someone chime in on what else i need?
Bought/In hand:
manual ECU
shifter assembly
OEM clutch cable
clutch pedal and brackets
Linkages
tranny-block metal gasket
CS Rear Shift Stabilizer bracket
Clutch Kit (OE Exedy kit from Ebay)
Axle Shaft Seals
Flywheel Bolts
Drivers Side Axle (from Raxles)
Fidanza Flywheel
Pending sale:
wiring harness
transmission (b13 LSD)
brake pedal and brackets
rear engine mount
crossmember (b13 and p10)...i didnt know which one would fit so i bought both
rear crossmember bracket
part that bolts to shifter assembly inside the car (dont remember what its called)
shifter boot and knob
Need to buy still:
shifter assembly bits
short shifter kit
What else do i need?
The Emo Kid.
no passenger side axle needed. heres the p11 list, some of which may remind you of other things you need
-P11 Transmission or B15 Transmission
-P11 Rear Motor Mount Bracket PN 11332-2J200
-P11 Manual Transmission mount - PN 11220-7J401
-P11 rear motor mount
-Clutch and Pressure Plate (bolts also)
-Hydraulic Clutch Pedal and Master Cylinder
-Hydraulic Slave Cylinder
-Shift Linkages
-Drivers side axle
-Axle shaft seals for the tranny
-brake pedal
-5 speed Shifter
-5 speed Shift Surround
-clutch line
-Hydraulic Clutch *Dampener*
-P11 two piece flywheel
P10 FTMFW!!!
Hrmm...seems like the one thing i forgot was the axle shaft seals...i also have to see which transmission mounts i need...the b13 ones or the p10 ones...but it looks like i got the list pretty much down...when its done ill make sure to do a write up on the exact parts for my car i use.
P10 FTMFW!!!
I'll do one once its in =)
P10 FTMFW!!!
Discussion Starter #10
So I just had a chat with Marty over at Raxles...from what i read here, seems like he's the man to goto for axles. He definitely knows his stuff and is building me a new driver side axle to put the b13 transmission in my p10...f'ing sweet =)
P10 FTMFW!!!
Discussion Starter #12
bhowle said:
Just out of curiosity, is that a cable or electronic speed sensor on the B13 transmission?
Depends on the year...when i talked to JustinP10 today i actually asked him about this. It's the same way as our transmissions...end of 92 and earlier, its cable. Afterwards, its electromechanical.
P10 FTMFW!!!
Discussion Starter #13
Ohhh...i also ordered the axle seals and the flywheel bolts today...JustinP10 is the man, if you need anything new...everythinginfiniti.com, get the number and call them guys up!
What do you need to get a custom axle built for ?
Chris
P10 FTMFW!!!
Discussion Starter #15
Since I needed to replace the axle anyways, i wanted something of good quality. Everyone seems to rave about Raxles, plus i know i would get the right part from them. It definitely seems worth it.
P10 FTMFW!!!
Discussion Starter #16
Ok well i recieved more parts today...I'm editing the list in a quick second.
hey if you need anymore parts,
I have a friend working at a Salvage yard in Yonkers, NY
Saw Mill Auto Wreckers 800-227-1111 EXT 113, ask to speak to ROB, tell him Fullah gave you the number
P10 FTMFW!!!
Discussion Starter #18
Awesome thanks man...ill give him a call if i need anything still =)
P10 FTMFW!!!
Discussion Starter #20
p10det said:
you use the p10 mounts
Yeah i confirmed that the other day...so now i gotta get them...but im getting much closer to getting you some work Mike =)
1 - 20 of 31 Posts
