I'll try to get a pic, might take me awhile. Also no wiring, just two bulbs for the guages, and they were stuck in the plastic bases so I had to break the old bulbs out to get the new wedge leds in.Can you post a picture, because I have an 02 sport and I am very interested in this aswell. So all you did was put the l.e.d.s in NO wiring?
does the needle light up well at night? or any dead spots?I just changed my cluster lights on my '02 sport to blue leds using the howto walk through and it worked fine. I used the #74xhp3 from superbrightled.com, the difference is you only need two bulbs to light all four guages. I bought 6(1 extra just incase) bulbs for the gauages and was confused when I got to the cluster because the only bulbs you can replace are the two for the guages, left turn signal, right turn signal, and the brights light signal.
