1 - 15 of 15 Posts
I was wondering if anyone has ever tried to install a 10" or 12" in the rear deck of a P10?:-\
G20 Junkee
I haven't done it myself but I have seen someone who has it done. If you want pictures I can hook you up. If you want to know how it sounds I cant help ya
Yeah, if you can give some info and pics, I'd surely appreciate it. =)
trbobrk said:
Here is a picture of a 15" sub in the back of that teal NZ P10 with the areotech kit.
Whoa! A little too much for me. But it is encouraging to know that if a 15" can fit, a 12" should be no problem.
My plan(in a few months, I hope) is to add a sub to the stock system, and have it set up so that it'll be a real bitch to steal the sub or the amp without taking a lot time and hassle. :bandit:
G20 Junkee
Sorry bro, that was the exact same set up that I myself was going to go with. Thats the idea I'm considering now!
no, dont know anyone with a p10 that has one but if you decide to...make sure the sub is designed for a infinite-baffle (free-air) setup...also dynamatting your rear deck will help with the vibrations...
btw, doing a IB setup is always good for SQ but will suffer some SPL and low end because its not in a box...but i'm sure its loud enough for an average listener
anyways, i suggest getting a JL Audio 10-IB4 or 12-IB4...with like 150-200 watts and it'll jam and sound awesome. good luck
Discussion Starter · #7 ·
Thank you all for the input. I'll let you all know how it turns out.;)
I was just thinking about that too after installing my rear speakers couple days ago! Either 10's or 12's whatever is easier to fit. But it has to be a good free air subs then, huh? Please let me see photo's before I proceed so I could see how it looks;)
Ok, myth, IB actually does BETTER on the low end than conventional sealed boxes, OR typical ported boxes. I am in the middle of an IB setup using 2-12" drivers. I have chosen Elemental Designs e12a's for my install, they have rather strong motor, they can handle alot of abuse, and have a rather high Qtc making them great for an IB setup. I will be feeding each driver 500w rms from a Soundstream Rubicon 1002.
This is a link to a bunch of my pics, Im sorry the pics are so HUGE!
http://www.soundillusions.net/sites/jlaine/MentalInstall/
:confused: Oh boy..., anyway, no you need a TNT explosive strap in the center of your rear deck, depending on how big the hole you wanted to be..., just kidding folks;) Seriously, you need a jig saw with metal (saw) cutting capability and yeah!, you (must) definitely need an amp to drive any subs.
Good Luck =)
1 - 15 of 15 Posts
