1 - 7 of 7 Posts
well it will make the sidewall just shy of an inch bigger all the way around (20.5mm), your width will stay the same. so assuming you are mounting these on the same offset rims. ask yourself these questions. if i crank the wheel all the way both directions do i have more than an inch clearance all around with my current setup. and allow for suspension travel
phxg20 said:
That size fit fine on my p10 with 38mm offset wheels. Search for the suspension/tire guide. Your answer will be in there for sure.
Really ??
205/50-16s on 7.5" wide wheels with 38mm offset rubbed on my P10 until I rolled the arches. The 50mm drop probably doesn't help,
1 - 7 of 7 Posts
