Sup G.Net!
When swapping trans from non-lsd to LSD, do you need anything from the engine block or just the transmission casing?
Before boosting, what replacements would you make to an SR20DE Rr engine if it had 190K on an auto trans?
Recently salvaged an A/T LSD touring transmission (from a 2001) along with it's flywheel and torque converter.
Is there a difference between the non-Lsd and touring torque converters or are they interchangeable?
Do I need to be concerned about any differences in ECUs? my vehicle is a 2000 and the trans came from an 01.
When going turbo with a USDM rr engine, if you were going to boost less than 7-8 PSI, what diameter exhaust would you go with? Is there any benefit to going over 2.5?
