B15 LSD transmission...
911 Views 15 Replies 6 Participants Last post by  vtech killa
Nvm.
1 - 16 of 16 Posts
Selling off all of my spare parts to fund a new car. Clean unmolested B15 LSD trans. Still hydraulic. I am asking 700$ OBRO. Feel free to PM me an offer. I would like it gone soon. Located in Rock Hill, NY. Willing to meet. PM or you can text 860-508-6131. Let me know. Thanks!
Bump for a nice upgrade for the P10 transmission :) I wish I live close as I'm buying a local Transmission for my DET setup Good luck with the sale :)
Thanks man!
It should be a nice upgrade for all setups including the N/A guys. Little bit tighter gears with the extra strength.
Thanks man!
Yes for sure man they say the B15 LSD is the holy grail of transmissions :) from an article I read below :)
http://voices.yahoo.com/sr20de-sr20det-sr20ve-transmissions-which-choose-5319663.html
" SR20DE, SR20DET and SR20VE Transmissions: Which to Choose for Your Application
Seth Joyner
Seth Joyner, Yahoo Contributor Network
Jan 26, 2010 "Share your voice on Yahoo websites. Start Here."
MORE:TransmissionG20Infiniti
FlagPost a comment
Picking a transmission for a front wheel drive sr20de, sr20det, and sr20ve is more of a science than an art. There are many different sr20de compatible transmissions to choose from some are weak and others are almost indestructible; some have limited slip differentials and some don't and they all have different gear ratios, in this article I will describe the different transmissions available for the sr20de and variations of that motor to help you select the best transmission for your application. I will also include information for aftermarket sr20de transmission parts, tips, and things to watch out for.
P10 91-93 Infiniti G20 sr20de transmission.--this transmission has the longest gears of all the sr20de transmissions and is best suited for someone that does a lot of interstate traveling, it's a good transmission for fuel economy and works best on motors that are modified with a smaller turbo such as a t25 or a t28, it does not work well with larger turbos because the gears are so long it's practically impossible to load the engine down hard enough to get a good spool. This is a weak transmission, not good for much over 250 horsepower and does not handle 4 and 6 puck clutches very well; the transmission seems to self destruct with use of these clutches. Limited slip differential versions of these transmissions are hard to come by as it was only an option, most are one wheel spinners.
P10 93.5-96 Infiniti G20 sr20de transmission--this transmission is exactly the same as the one mentioned above except for the fact that it has a steeper 4.176 final drive, which would allow it to be suited for a slightly larger turbo such as a super 60 T3 or at biggest a T3/T04E 50 trim with a 48. A/R exhaust housing or a gt2871r. This transmission and the one listed above are not suited for all motor performance and are best left to turbo applications because of the wide gear spread they also have a lesser tendency for wheel spin after first gear with good tires.
P11 1999 Infiniti G20 sr20de transmission--This transmission is similar to the transmissions listed above in first gear, second gear, and final drive; but it has tighter 3rd, 4th, and 5th gear spreads. This transmission would be a better turbo transmission for racing from a 40 or 50mph roll and has a lower gear limited top speed which is good because there's no point in racing in speeds over 130mph anyway. This transmission still has a weak case, so don't be fooled if it looks different on the outside. This transmission also comes limited slip or not. This sr20de transmission is also suitable for all motor and nitrous applications, it has exactly the same gearing as the 91-99 B13 and B14 Sentra and 200SX.
P11 00-02 Infiniti G20 sr20de transmission--The transmission with the improved case. This sr20de transmission is similar to the one above, but it has a stronger improved case and first and second gear are tighter. This is a good all around transmission, it works well in most situations and is normally pretty hard to come by in its lsd (limited slip) format.
B15 00-01 Sentra 2.0 sr20de-This transmission is the most sought after, especially when its lsd. This transmission has a 4.437 final drive which is quite a step up from the 4.176 final of the transmissions previously mentioned, first and second gear end quick with this transmission making it a good tranny for all motor sr20ve or turbo usage with good tires. This transmission is good for about 450 horsepower stock without failing.
N14 Pulsar VZR sr16ve-this is the bad boy for all motor, it has the same tight first and second gear ratios as the B15, but has tighter (shorter) third, fourth, and fifth gears. You'll rip through the gears like you're on a motorcycle with this one. This transmission is not normally recommended for turbo sr20de's unless you're using a fairly large turbo and you have a high revving engine with slicks. This is a very strong transmission and like the B15 it takes well to puck style clutches, the B15 and the sr16ve transmissions will cost you the most, but they are the best front wheel drive bolt in transmission that Nissan has to offer.
TIPS
**Modifications can be made to your weak B13, B14, P10, and early P11 sr20de transmissions to make them more capable of higher horsepower and torque levels. You can aluminum fill weld the crescent shape around where the passenger side cv axle enters the sr20de transmission differential. Having your transmission gears shot peened and cryo treated will also improve strength.
**Use Redline shock proof gear oil, it's makes for smoother shifts and is better at protecting your sr20de transmission than conventional gear oil.
**Always use a light weight sr20de flywheel, this reduces the amount of rotational inertia that the transmission has to absorb when selecting a gear, it can help make your sr20de transmission last longer.
**Avoid puck style clutches on your sr20de transmission unless it is necessary at your power level. Also, when using puck style clutch disc, try and mismatch them with a lighter duty clamping force pressure plate, this will allow the clutch to slightly slip.
**This is a link to sr20de transmission gear ratios, engine rpm in gear, and mph for each gear: http://www.sr20forum.com/driveline-transmission/104113-gear-ratios-b13\14-p10\p11.html
**There are semi-synchro and straight cut dog box gear sets available for these sr20de transmissions from PAR engineering, but you'll have to put down a pretty penny to have an indestructible transmission.
**Fifth gear pop out is a common problem on the early sr20de transmission, here's a link to the replacement parts: http://www.gspec.com/s-14-transmission.aspx
**The only good replacement sr20de differentials for racing applications are made by Quaife and Nismo, do not get a phantom grip."
quote from that web page Good upgrade for sure :)
Exactly. If any big power guys who rarely street drive, there is a gear cuff that will be made to hold the gears together better to help with our gears "pushing away" at each other. Still in the R&D phase but I'm sure it will be made. Only downfall to that will be the loss of 5th gear due to the cuff taking its place. Excellent alternative to the 6 speed swap and guys on a tighter budget/have a twin disc, etc for their 5 speed.
Man you're only about 1.5 hours away and I need another trans for my extra motor....
You used this trans? Are you sure it's working?
Yes its 100% working order. Pulled from my brothers totaled B15. This was a back up for my 2.3 if I grenaded a trans at the track. I didn't want to convert it just yet since its simple enough to convert if the buyer is putting it in a 91-99. Car is getting a custom gearbox this year and putting the funds towards a tog hog lol. Let me know!
Nice... Might have to chat with you.
Feel free to give me a shout. I may be coming to CT to see my tuner next week.
Bump. 600$ picked up!
nismo tuner- Will transmission bolt right up to 2002 g20 p11?
I had a couple of guys inquire about shipping. I am just trying to come up with a safe way to ship it. I am scared the shipping company might drop it and damage it.
G20Prime, this should be a plug and play swap. I am not 100% but I know a couple of the P11 guys up by me have used the B15 trans.
When I got my tranny ship to me, he used a square wood board and screw it to the bell housing part of the tranny so it sit up and doesn't tilt or fall. That way so UPS or any other handler have to keep it up right. Got it in good shape but got f**k over with a lie about fixed 5th gear pop out.
Just posting up. If I don't have a serious inquiry by tomorrow 12pm, I'll just convert it to cable and run it in my b13. Thanks!
1 - 16 of 16 Posts
