I was wondering if any of you guys that have aftermarket systems use a second battery rather than connecting it to the main battery that the engine uses.
Im also wondering if somebody connected their amplifiers to the batteries without alternators
if you need that much power your better off buying a capacitor. -much easyer to install.
anything over 800watts a second power source is a good idea
:nervous:
i don't know much about car audio installation but i will share what system i have.
* 2 rockford 700S powering both solo baric 12 L7's
* 1 RF 500X for the front and rear speakers.
my lights used to dim even with low volume. i have then a yellow top battery and two 1 farad capacotors. my friend then installed a second yellow top battery at the trunk which i think powers up the system because he installed two circuit breakers (one in front after the 1st battery and one at the trunk before the second battery). when i turn of the circuit breaker the system totally shuts down but the receiver still works. i don/t understant the whole set up but i hope you'll get an idea with my system set up.
