1 - 16 of 16 Posts
I just got an XM kit for my car, and I'm thinking about doing the following for the antenna: antenna magnetically affixed to trunk lid. Cable runs into the trunk, through the folding seats and then runs unobtrusively along the passenger's side and then up to the center console where the radio unit itself is. Is there a better mounting point signal wise? I know that the rear of the roof might be better but there's no way to run the cable through cleanly without a professional install which I don't feel like paying for.
The antennas work good, inside the car near the rear window etc. You don't have to leave it on the outside. Just letting u know, if u don't know.
P11jdnkola27 said:
got mine on the roof. went thru the window seal
That's where I have mine, the wire is skinny enough to tuck under the window molding around the rear window and then into the trunk.
It usually works fine sitting inside the car on the back package tray, but the sound would sometimes fade-out when next to a Semi-truck or tall trees or in a drive-thru. Haven't had that problem when mounted on the roof.
i put mine in the third brake light. its hard to see, it works great, and i always get compliments about the placement.
I Gots More NISMO Then U!
well let me give you another one! good placement, never thought about that.
Anywhere outside of the car, with the least obstructed view of the sky will logically give you the best possible signal. It WILL work inside, but I highly recommend placement on the outside.
i have 5 bars. it doesnt get any better than that
"says here on your chart"
i used to think that as well, but it really doesn't matter, you can put it inside no problem. Logically, XM and Sirius use ground repeaters anyway. this is not like your home sattelite, it's dif technology. inside the car is fine. ive driven all over with it like that.
Ahhh F that, install it inside the car. Stay nice and sleek.
However, if u live far from city u may have issues. Sad to say... XM need repeaters, more than anything.
If you do a little searching, Google Maps can actually show you where the ground repeaters are lol.
1 - 16 of 16 Posts
