Put the G in the garage to tear the turbo system out and replace with a revised setup and change the intake cam and thought I would play around with a different brake setup. So far I am sticking with 2008 350Z twin piston calipers and 320mm rotors in the front. The rears are A32 Maxima with Baer rotors for the same A32 277mm application. Looks awesome but I didn't have enough time to finish this weekend... So far I had to redrill the front 2x caliper bracket bolt holes a tad larger, and the 320mm rotors touch the caliper so I am going to turn the rotor down a little or carve the inside of the calipers tonight... The rears are just a bolt on deal.
320MM 350Z Fronts
277MM A32 Maxima rears
