does anyone know how to install the blower motor for a 91 g20? the air isn't working and i was told it's the blower motor. i'm in florida i need air!! help anyone
First off...Welcome!
It could be the blower resistor...does your fan work @ all?
The resistor is easier & cheaper to replace than the blower motor...it's located on the bottom of the blower housing under the passenger side dash...
Just something to check first b4 you get into the blower motor..
Putt
hi again, the fan doesn't turn on at all. this guy showed me that it still works but i have no clue what to do
My blower does not come on at the HIGH setting (#4). Installed a new Blower Motor Resistor, brought back fan Settings 1 - 3. I was told by the mechanic that Setting 4 is wired through the RELAY, not the resistor. Where is the Blower Motor RELAY?
