just to add to this the "running lights" turn on so they are getting power. the turning signal and the reverse lights work too.
im considering itBurn it.... start over.
thats interesting. where exactly did it short in the wiringGood luck...I just had a similar problem - it was a short in the brake light switch wiring. Took several hours to repair.
what did you swap?Watching this thread, had the same problem after my swap and haven't fixed it yet.
I suspect the original owner closed the trunk on the wire harness that goes along the side of the lid. It's very common for these wires to get pinched in that location (search for it, I think there's at least 3 or 4 different threads about it). Regardless of what happened, the original owner replaced the trunk wiring and all the wiring going to the ABS computer and the brake pedal switch wiring - although it looks like they got lazy at the end and the new wires to the brake pedal switch came loose - causing a short.thats interesting. where exactly did it short in the wiring
Oops, didn't see your comment. GTi-R engine swap.what did you swap?
